Bravo 3
Old 04-30-2021, 07:45 PM   #1
Shanea55 is currently offline
My Model: Talari 200
My Engine: 350
Send Shanea55:
Default Bravo 3
I am restoring a 1994 Mariah Talari 200 it had a blown up 305 in it with a bad drive got it for a gr8 deal. I have found a mercruiser 357 Magnum Bravo 325 hp 5.8 L suppose to have same torque as a 454 and more horse power. I think I need to have a bravo outdrive that will handle the hp and torque of this engine so I got a bravo 3 outdrive whole assembly with transom and all for a good deal it has low gears in it 2.43 but it was in good shape along with the 24" props or should I go with bigger props 32" ? Or find out what gear ratio to go with to using what props? I was thinking of replacing the upper drive with bravo 1 since they interchange but want to know what would be a good ratio considering the boat weighs 2550 empty and its almost 20' long.
I would appreciate any thoughts or suggestions thanks Shane HELP
  • Old 05-03-2021, 12:29 AM   #2
    dustinnantais is currently offline
    My Model: Z275 Shabah
    My Engine: 7.4L Merc Mag Bravo3
    Send dustinnantais:
    Default Re: Bravo 3
    Damn, that thing will rip with that motor. Very light for that much power. Good luck!
    Old 05-03-2021, 02:51 PM   #3
    My Engine: 350
    Send Shanea55:
    Default Re: Bravo 3
    Thanks. Hopefully it will be on the water soon.
    Bravo 3 2.20 Plandreth Mercury MerCruiser 1 09-01-2018 04:04 AM
    5.7 Bravo 3 Vs. 7.4 Bravo 1 Talari Ikepieman Original Mariah Talk 7 07-04-2016 02:48 AM
    Red 210 LE 7.4 Bravo 1 rayzorback Mariah Boats For Sale & Wanted 8 07-06-2013 12:27 PM
    Bravo III for Bravo I Motoxxx43 Original Mariah Talk 6 05-01-2013 04:48 PM
    bravo III pitch rusty Prop Talk 3 06-06-2009 01:12 PM
    There are 263 users
