Bravo III for Bravo I
Old 04-30-2013, 04:35 PM   #1
Question Bravo III for Bravo I
Long story short I have a friend with a Bravo III on his 18' Crestliner. He wants to sell the Crestliner and realizes the BIII is a bit over kill for it. He asked me if I would be interested in swapping my Bravo I for his III. I know the value of his is higher than mine, ideally. Keeping in mind I just had my outdrive rebuilt (prop shaft, seals, bearings, etc) and prop worked over by a shop it looks brand new, literally. His Bravo III came off a salvaged boat (auto accident while on trailer) and has very low hours. After doing some poking around Im not coming up with a number I should offer him for the difference. I do know know how the props will do that are on the III though he has two sets. Im only interested in one set that works best.
Id be happy to hear some ideas/numbers from MOC members... Thanks!
The reason I am considering this is I really want some more control at lower speeds. The 250 handles nothing like the SC21 and is proving difficult to maneuver in the marinas when the wind picks up. My bow definitely has a mind of its own, it likes to wander.
  • Old 04-30-2013, 04:45 PM   #2
    Default Re: Bravo III for Bravo I
    Been there, done that. I know EXACTLY what you mean!!
    I say go for it. The B3 is amazing for maneuvering. Before you make the deal, I'd get the B3 thoroughly checked out by a Mercruiser mechanic first though, just to make sure everything is in good shape.
    Old 04-30-2013, 05:11 PM   #3
    I plan on it. What do you think for a price? My drive plus 500$?
    Old 04-30-2013, 05:36 PM   #4
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    i think that would be a fair trade deal.
    what gear ratio is his ?
    what props does he have ?
    I have not done it, but it's my understanding you only need the swap the lower units, all bravo uppers are the same (just some more beafy'er then others.....i.e. B2, XR, etc.)
    2000 Z302 Bow Rider
    Old 04-30-2013, 05:54 PM   #5
    Ratio an props I'm not sure of yet. We will hook them up one day an go for a spin. I can experiment with the props then. As it is I'm running the 1.5 with a 19p an it runs pretty good.
    As far as I know the Bravos are interchangeable like you say.
    Old 05-01-2013, 04:47 PM   #6
    I looked around on some forms and have not really read anything that gave me an answer but about the drive ratio... My current bravo1 is a 1.5. Is it safe to assume that a bravo 3 with a 1.5 should be the same or does it change the whole set up?
    I suppose the ultimate way to find out is to actually test the drive with the two different sets of props
    Old 05-01-2013, 04:48 PM   #7
    Gallery Images: 36
    Send Oregondunes:
    I read somewhere years ago that the 2 to 1 ratio was the one that you wanted to use if you're doing the conversion
    2000 Z302 Bow Rider
    bravo III coupler pokes Mercury MerCruiser 1 03-25-2013 03:35 AM
    winterizing Bravo III pincourtmariah Mercury MerCruiser 12 12-05-2010 02:32 PM
    Z272 with a 502 Bravo I apickens99 Prop Talk 1 06-03-2010 01:17 AM
    bravo III pitch rusty Prop Talk 3 06-06-2009 01:12 PM
    need new bravo three drive luv2boat Mercury MerCruiser 6 08-30-2008 09:54 AM
    There are 371 users
