MSD Distributor to Shift cutout switch
Old 05-09-2018, 12:52 PM   #1
NoCoBoater212 is currently offline
My Model: Shabah 212
My Engine: 5.8L Alpha One
Send NoCoBoater212:
Default MSD Distributor to Shift cutout switch
I need some help, I replaced my engine and moved from the Thunderbolt V ignition system to a MSD Marine distributor. The wiring out of the MSD is not the same as the Thunderbolt V and does not connect the same. Does anyone have an idea how to reconnect the shift cutout switch using the wiring from the MSD Distributor? Do I route the black wire through the cutout switch gray wire first and then onto the negative side of the coil? I need to get it hooked back up. Thanks for any help!
Engine is a Chevy 5.8L Carbureted Alpha 1. I removed the stock Mercruiser 350 mag with a Thunderbolt V ignition system.
  • Old 05-10-2018, 03:05 AM   #2
    Send NoCoBoater212:
    Default Re: MSD Distributor to Shift cutout switch
    Ok an update, I believe I have located the solution. The shift cutout switch has the white/grn and a black wire coming out of it(old style lever switch) The white/grn will now go to the negative side of the coil and the black wire it route to a ground. Once I get it connected, I will update the post if it works correctly.
    Old 06-07-2018, 04:42 PM   #3
    Send NoCoBoater212:
    Ok update, yes this is the correct way to wire the shift cutout switch. Wht/Grn goes to negative side of coil and black goes to ground. Tested this last weekend and everything is working correctly.
    ______________________
    Josh
    1996 Mariah Shabah 212 - 5.8L Vortec Alpha 1
    #8 of 10 Produced for the Dealer Meeting
    Polo SuperSport Interior
    2001 Mercruiser 5.7 EFI distributor question donly1 Mercury MerCruiser 3 09-04-2017 03:33 AM
    distributor rswerdan Mercury MerCruiser 5 07-11-2014 08:34 PM
    What is a shift interrupter switch ? jchemotti General Maintenance 4 08-03-2012 04:14 AM
    enigne cutout switch wiring elimont Mercury MerCruiser 3 08-20-2010 09:40 PM
    Squeal in Distributor wplaine General Maintenance 3 09-25-2009 11:03 PM
    There are 374 users
