Squeal in Distributor
General Maintenance
Old 08-26-2009, 11:10 PM   #1
wplaine's Avatar
wplaine is currently offline
My Model: Z215 Talari
My Engine: 5.7L Bravo III
Gallery Images: 15
Send wplaine:
Default Squeal in Distributor
I have a loud squeal from the distributor.(thunderbolt V) Cleaned the cap interior and pulled the distributor to lubircate it. It stopped squealing for about 2 minutes then started again. Any one know a possible fix? Thanks, Walter '96 Z215 Talari 5.7 L Bravo III
  • Old 08-29-2009, 06:34 AM   #2
    Default Re: Squeal in Distributor
    Hi wplaine,
    Unless it's coming from the rotor inside of the cap, you may have an upper shaft bushing going out on the distributor. I would apply some "dielectric" (available at any auto parts store)grease on the center contact of the rotor and inside of the cap and if that doesn't work, I would try squirting a little WD-40 down into the upper bushing on the shaft underneath the rotor to see if that quiets it down.
    Old 08-30-2009, 01:05 AM   #3
    wplaine's Avatar
    Gallery Images: 15
    Send wplaine:
    Will try all of that. 'Towing to the outer banks of NC tomorrow on vacation and working on it while improving it. I have had it three weeks and fixed probably ten things.... Your help is appreciated.
    Old 09-25-2009, 11:03 PM   #4
    wplaine's Avatar
    Gallery Images: 15
    Send wplaine:
    Thanks for the info. Tried the dielectric gerase. Squeel only starts once warmed up so the hunt continues....
    Alpha 1 squeal when triming?? midwest mariah Mercury MerCruiser 5 08-18-2009 04:07 PM
    There are 298 users
