What is a shift interrupter switch ?
General Maintenance
Old 08-01-2012, 11:56 PM   #1
jchemotti is currently offline
My Model: 180SE Shabah
My Engine: 3.0 LX
Gallery Images: 1
Send jchemotti:
Default What is a shift interrupter switch ?
What is its function?
If it's not working, what would be the symptoms?
If it needs replacement, does the engine/outdrive ID # need to be matched with the part?
Coulld a faulty shift interrupter switch be confused with a problem with the shifting cable?
As always, thanks for your responses..
Jan
1997 Shabah 180SE
3.0 LX - Alpha
A perfect mix ~ my dog, a book, my boat.
  • Old 08-02-2012, 02:26 AM   #2
    Default Re: What is a shift interrupter switch ?
    This switch allows the drive to shift back into neutral with less effort. If the switch is defective or disconnected it will be very difficult to get neutral. If the shift cable is bad, it can cause the switch to "over-activate" and stall the engine when you shift. And yes, you need to know your engine/outdrive ser# but... be aware that the more usual cause is a faulty shift cable.
    If you want to read a good detailed but straight-forward explanation of the shift mechanism & problem solving click on this link.
    Old 08-02-2012, 11:43 AM   #3
    My Engine: 3.0 LX
    Gallery Images: 1
    Send jchemotti:
    Thanks Mikey...
    so, if the remote on our boat had a recall, might that be connected - pardon the pun - to this issue, 'cause I don't think that was ever fixed... (Quicksilver 300 classic)
    Jan
    1997 Shabah 180SE
    3.0 LX - Alpha
    Old 08-02-2012, 02:30 PM   #4
    Originally Posted by jchemotti View Post
    Thanks Mikey...
    I dont believe the Quicksilver 3000 series control on your boat was involved in the recall as it only covered the units built between June 1994 and Sept 1995. Here's a link to the actual recall notice posted by 'bdbyrnes'.
    Old 08-03-2012, 04:14 AM   #5
    My Engine: 3.0 LX
    Gallery Images: 1
    Send jchemotti:
    I have to call Mercury Marine and give them the HIN and Serial #s of the engine and drive, to find out if I have coverage.
    Jan
    1997 Shabah 180SE
    3.0 LX - Alpha
    torque shift, worth the hassle? booiea Prop Talk 4 08-26-2010 11:45 PM
    Bravo One Shift Bellows Z212NH Mercury MerCruiser 2 07-26-2010 01:28 AM
    What does this switch do? Frankpypr Original Mariah Talk 4 06-16-2010 03:29 AM
    Shift cable problems jasfiveo Original Mariah Talk 2 06-16-2010 12:06 AM
    slow shift into gear bubskunk Original Mariah Talk 0 06-15-2008 11:54 AM
    There are 262 users
