Mercruiser Power Steering Leak
Old 06-17-2015, 04:02 PM   #1
Medic1 is currently offline
My Model: Shabah 202
Send Medic1:
Default Mercruiser Power Steering Leak
I was told I may have a power steering cooler leak, it is a fast leak and keep the reservoir filled with fluid. First of all where is the power steering cooler located, does the motor need to be removed to fix or replace? I was told they would have to remove the lower unit and motor to get to it. Does it hurt the system if I continue to use if I keep the reservoir filled until I can get it fixed?
Having difficulty finding diagrams or instructions on the replacement of the steering cooler.
  • Old 06-23-2015, 02:17 PM   #2
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    Default Re: Mercruiser Power Steering Leak
    I just went through this on my Jubilee. Not sure what motor you have. I have a 4.3 and the cooler is at the top rear of the motor. It has 2 larger water lines and 2 power steering lines hooked to it. Once the lines are off, there is 1 bolt holding it to the block. On the jubilee, it can be accessed without removing any other parts. A mirror is helpful to see what you're working with back there.
    On mine, I was loosing fluid, but nothing showing up in the bilge. To verify that it was the cooler that was leaking, I bought a hose barb, unhooked the input and output PS lines from the cooler and bypassed the cooler. I have run a few times since and fluid level has been steady so I'll be replacing the cooler.
    A google search, then view images, and you'll have plenty of diagrams showing the layout.
    https://www.google.com/search?q=merc...ph-cAm7BKXg%3D
    power steering cable bethk Original Mariah Talk 3 10-31-2021 09:36 PM
    power steering freeman81 Boating 101 7 02-04-2011 06:53 PM
    3.0 Mercruiser Riser to Manifold Leak 1999Mariah Original Mariah Talk 2 06-12-2009 01:14 PM
    2350 Z power steering cleah Mercury MerCruiser 2 09-09-2008 02:17 AM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    There are 340 users
