New Owner/ Erratic trim indicator
Introductions
Old 06-17-2013, 04:16 PM   #1
tcjr88 is currently offline
My Engine: 454 Magnum Bravo I
Send tcjr88:
Default New Owner/ Erratic trim indicator
Hi, Just Bought a 1996 240Z Talari with the Bravo one and 454 magnum. Trim indicator erratic and i don't think reliable, looking for some help. Thanks Tim
  • Old 06-17-2013, 05:25 PM   #2
    Default Re: New Owner/ Erratic trim indicator
    Welcome to MOC Tim
    1) Check wiring connections to the gauge and to the sending units at the drive.
    More than likely trim sending units are bad.
    Check out this thread.
    If you do a search for trim issues there are quite a few threads on the subject.
    Once again...........Welcome!!
    Old 06-17-2013, 05:28 PM   #3
    hi Tim & welcome aboard. This is one of those subjects that has been beaten to death around here. The cause is usually down to a poor electrical connection at the trim motor and/or trim solenoids, or a failing or failed trim sensor on the outdrive. I would suggest that you read the following two 'stickys' that will help you determine where the problem lies before someone here posts a 'i dunno how to help you but i would sure like to cuz i might have to do this myself someday' type response.....
    Troubleshooting your Power Trim/Tilt System
    Adjusting or replacing your trim sensors.
    Replacing those sensors is a bear of a job since it requires removal of Mercruiser outdrives. And no, i dont want to hear from the Volvo outdrive owners on how easy this job is...
    Keep us posted on how you make out!
    Old 06-17-2013, 06:38 PM   #4
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    I replaced the trim sensor on my Volvo leg at the weekend.
    Horrible job! took me nearly 10 minutes!
    Old 06-17-2013, 07:43 PM   #5
    Andy is blind, Andy is. I dont wanna hear from the Volvo outdrive owners...
    Here's another link from MercStuff.com for adjusting the trim/tilt sensors. If the wires leading to the sensors are broken, you can try repairing them but is usually means replacement time.
    Old 06-17-2013, 07:59 PM   #6
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Andy is blind, Andy is. I dont wanna hear from the Volvo outdrive owners... .
    Ah your just jealous
    Old 06-17-2013, 08:51 PM   #7
    Congratulations on the boat! How about some pictures !?
    For Sale: Volvo Penta Digital Trim Indicator Gauges marinesupply Mariah Parts For Sale & Wanted 4 02-28-2013 01:01 PM
    mariah sx19 mercruiser alpha trim up trim gauge bad mrtransistor Mercury MerCruiser 1 08-05-2010 03:37 AM
    Outdrive Trim Sensor & Trim Limit Switch Replacement WetWilly General Maintenance 0 05-26-2009 06:01 AM
    trim dieselwiezil Original Mariah Talk 1 08-01-2008 08:27 PM
    There are 252 users
