Electrical
Old 04-03-2009, 02:00 PM   #1
Z210Shabah's Avatar
Z210Shabah is currently offline
My Model: 1997 Z210 Shabah 5.7 E
Send Z210Shabah:
Default Electrical
Hi everyone-I had a slight problem last year(or maybe not)I put a new alternator in my boat and new battery(It needed them).If I run my stereo or lights or anything,I notice the volt meter will drop from 12-13 to 8-10.Is this common or do I have a problem that should be looked into-Thanx-L.J.
  • Old 04-03-2009, 02:28 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: Electrical
    Mine does something similar... If I switch on the docking lights while at idle (sometimes even without turning the lights on!) my volt meter will read around 10. If I rev it up a bit, it will go back to 13-14. I always thought it's my alternator going bad, and never let it concern me too much.
    Did you replace the alternator with OEM equipment?
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 04-03-2009, 06:47 PM   #3
    Jayhawk04's Avatar
    Jayhawk04 is currently offline
    My Model: 1993 Diablo 4.3l Alpha I
    Send Jayhawk04:
    You might try running a bigger ground from the battery to the distribution block under the dash. I know in mine, the ground was pretty small and when there are multiple accessories trying to pull current through the small line, something has to give. I had problems, epically when I had the stereo on and I turned on the docking lights... the stereo would cut out and the voltage gauge would drop. I ran a thicker ground and all the problems went away.
    Old 04-05-2009, 11:40 PM   #4
    Jayhawk04's right, with bigger accessories and more powerful stereos, the current handling capacity of the stock wiring can be over taxed. Running thicker gauge wiring for the + and - from the battery to the distribution or fuse blocks wouldn't hurt.
    For power hungry devices, a separate fused wiring circuit should be considered.
    The last thing to check is any corrosion at the connection, fuse blocks and terminals. As the current load goes up, any corrosion creates more resistance in the circuit so keep those exposed connections clean and if possible, watertight.
    Intermittent Electrical Problem jwpilger General Maintenance 13 08-13-2009 02:44 AM
    Electrical problems on my 94 talari Z Brian Original Mariah Talk 5 06-20-2008 10:35 PM
    Marine ACDC electrical site mikeyt General Maintenance 0 03-05-2008 12:37 AM
    electrical problem nickc Sea Fox - Mariah Talk 4 02-24-2008 06:34 PM
    Electrical Fix Straad General Maintenance 2 08-28-2007 12:26 AM
    There are 259 users
