Discoloration on hull along waterline
General Maintenance
Old 07-24-2015, 12:49 AM   #1
yamahaR6 is currently offline
Send yamahaR6:
Default Discoloration on hull along waterline
I have some Discoloration on lower hull at stern and along waterline. Any tips on how to remove? I tried acetone on a small area that was partially successful in removing it but was concerned that it might damage the gelcoat. Boat is only used on freshwater lake. Never left in water overnight. 1994 Talari.
Thanks for your help.
  • Old 07-24-2015, 01:00 AM   #2
    My Model: Z258
    My Engine: 7.4 & Bravo 3
    Send 99 Mariah 258:
    Default Re: Discoloration on hull along waterline
    I just wet sanded and buffed my boat it looks amazing. Watched a bunch of YouTube before I did it
    Old 07-24-2015, 04:06 AM   #3
    Most marine stores will carry a hull cleaner solution. Many of them use oxalic acid, which is great at removing the scum line and stains from the hull. It's some strong stuff, so make sure and wear some gloves, and cover your trailer if you're applying while it's on the trailer! But, it should take off some of the worst waterline stains. I leave mine in the water from May-November, and the stains outside of my antifouling bottom paint come right off with the oxalic acid hull cleaner!
    Here's what I've used previously.
    Bass Pro Shops Heavy-Duty Hull Cleaner | Bass Pro Shops
    West Marine, Starbrite, and others make similar cleaners. Just look for the oxalic acid on the ingredient list!
    yamahaR6 (07-27-2015)
    Old 07-27-2015, 01:32 PM   #4
    Send yamahaR6:
    Thank you for the help. I attached a pic of the discoloration mentioned. Do you think the cleaners you mentioned would work on this?
    Old 07-27-2015, 01:33 PM   #5
    Send yamahaR6:
    Thank you for responding.
    Old 07-31-2015, 12:10 AM   #6
    I think they would work on that. The only real way to find out is to try! The store brands (bass pro, west marine, etc) are only about $10/bottle, so I'd say it'd be well worth the cost just to test!
    Old 07-31-2015, 05:22 PM   #7
    mmckenzie6 is currently offline
    My Model: 202 shabah
    My Engine: 5.7 L Bravo I
    Send mmckenzie6:
    The other thing to remember is that you will need to wax these areas really well when you're done removing the stain.
    Otherwise, it'll be stained again after your first trip.
    Old 08-04-2015, 06:49 PM   #8
    Send yamahaR6:
    Thank you. I will give it a try and post some after pics.
    Old 08-04-2015, 06:50 PM   #9
    Send yamahaR6:
    Thank you. I will be sure to do that...though the water on our lake is crystal clear so hopefully this won't happen again.
    Bravo III Prop Shaft Discoloration Humpty Prop Talk 10 07-29-2014 07:12 AM
    Dashboard discoloration jjk61083 Original Mariah Talk 3 07-25-2012 05:54 PM
    I this the same hull CARL SWINDLE Sea Fox - Mariah Talk 1 06-04-2010 02:02 PM
    Need help with hull ID mjhinno Introductions 9 10-05-2009 10:31 PM
    Hull Cleaning andyc General Maintenance 5 10-01-2009 09:38 PM
    There are 239 users
