7.4 Mpi spark plug gap
General Maintenance
Old 08-15-2015, 02:04 PM   #1
My Model: Z258
My Engine: 7.4 & Bravo 3
Send 99 Mariah 258:
Default 7.4 Mpi spark plug gap
Anyone know the correct plug gap for a 99 mercruiser 7.4 mpi. Thanks. Can't find anything in the forums and google search is all over the place...Thanks
  • Old 08-16-2015, 12:36 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 7.4 Mpi spark plug gap
    According to the service manual it is 0.045".
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-17-2015, 07:04 PM   #3
    And just an FYI, expect to change the plugs about once a season, or two at max, if you want to keep the engine running optimally. Also good to change out the rotor button and distributor cap at the same time, if you use the boat a lot. For about $50 it's worth it.
    Old 08-17-2015, 10:52 PM   #4
    My Model: Z258
    Send 99 Mariah 258:
    Thanks guys. I did a tune up a couple months ago ...new quicksilver cap, rotor, wires, plugs and even a coil..but the wires were some off brand and plugs were ngk's so just to be safe I bought quicksilver wires and plugs and installed them. I noticed a slight stumble at idle that I never felt before and knew it had to be the plug's. Sure enough they came gapped to .030 so I pulled them all gapped to .045 and she's all better now...also got down in there and sprayed some rust converter and re sprayed the motor.
    Spark plug wires Juskol18 Mercury MerCruiser 7 04-04-2014 11:22 PM
    spark plug help Juskol18 General Maintenance 15 04-12-2013 03:35 AM
    Z202 oil and spark plug help Andy-Z202 Shabah Mercury MerCruiser 1 06-17-2011 11:19 PM
    spark plug help again aquaknot Mercury MerCruiser 4 09-12-2010 12:12 PM
    Spark plug MMarko Original Mariah Talk 1 03-16-2009 02:13 PM
    There are 309 users
