Exhaust Flaps
Volvo Penta
Old 02-04-2013, 03:11 PM   #1
clberkley is currently offline
My Year: 8143
My Model: JuliusdyeraJD
Send clberkley:
Question Exhaust Flaps
Just purchased 1997 Mariah 18ft shabah. My first boat, this one is in excellant condition, however the engine was lookup due to water in cylinders. I rebuilt the engine and now find that the flapper valves have been removed from the y-pipes. I also purhased new exhaust manifolds for my V6 engine. ,while installing the engine, one battery was hooked up backwards, I have not started the engine yet I am trying to find a wiring diagram as it has an onboard battery charger and a master control battery switch which lets you select 1battery 2battery, or all batteries. Do I need the flapper valves? I believe the engine flooded due to the missing flappers.
  • Old 02-04-2013, 06:41 PM   #2
    Default Re: Exhaust Flaps
    YES , do not put that boat in the water without the flappers installed! You'll be putting in another new motor faster than the power went out at the Superbowl.
    They run about 100.00 for the pair on Ebay. Just make sure you get the "New" style ones.
    Old 02-04-2013, 07:00 PM   #3
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Also, as it's your first boat. don't rev the engine before you shut the engine down!
    seen it happen sooo many times and all you do is suck water up the exhaust into the engine
    Old 02-05-2013, 12:18 AM   #4
    John Rush's Avatar
    John Rush is currently offline
    Send John Rush:
    Default Exhaust Flaps
    Do you mind explaining that more in depth regarding to the revving while in the water? Thank you
    Old 02-05-2013, 12:34 AM   #5
    I think Andy was refering more to a sudden shutdown while running across the water. When your at speed and suddenly throttle down fast(as in throw it in nuetral from say cruising speed)the water will back flow up the exhaust.
    The flaps help to reduce the chance of a hydro lock , but by no means are they a 100% cure.
    Old 02-05-2013, 05:20 AM   #6
    John Rush's Avatar
    Send John Rush:
    Note to self on that one!
    Old 02-05-2013, 12:26 PM   #7
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    As Colorado Diablo said but also I’ve noticed a tendency with people new to boating to "blip" the throttle before turning the engine off. (As you might with a car or motorcycle)
    But with a boat this can cause the engine to suck water back up the exhaust and into the engine! Not good...
    Old 02-06-2013, 10:41 AM   #8
    My Year: 8143
    Send clberkley:
    I want to thank everyone for their fast and efficient response to my post. Now on to finding the exhaust flaps, again any ideas would be greatly appreciated, by the way I teach automotive technology at a local secondary school here in Florida so I am versed in that field, it just that boats are going to be a new favorite hobby for my wife and I.
    Old 02-06-2013, 03:34 PM   #9
    Here is a place to start.
    Water Shutter Exhaust Flapper 4 inch Y Pipe Mercruiser V6 V8 807166A1 | eBay
    Just need to see if your pin holders are square or round.
    clberkley (02-07-2013)
    Old 02-06-2013, 04:08 PM   #10
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    have you told her that yet
    Thank you Andy b for this useful post!
    Thru Hull Exhaust my97camaro Original Mariah Talk 12 10-26-2013 02:11 AM
    exhaust seloniods karmann Original Mariah Talk 0 06-30-2011 04:53 PM
    Need Exhaust Switch Help Andy-Z202 Shabah Original Mariah Talk 1 06-17-2011 12:14 AM
    exhaust shutters rusty Original Mariah Talk 1 06-25-2009 03:27 PM
    Exhaust TALLRAM Original Mariah Talk 2 12-17-2008 05:08 PM
    There are 321 users
