Belt came off and overheated motor
Volvo Penta
Old 07-15-2016, 11:56 PM   #1
James Myer is currently offline
My Model: 220 Talari
My Engine: 5.8FSI S
Send James Myer:
Default Belt came off and overheated motor
I was on the lake today and noticed the boat was getting hard to steer. I saw it was overheated and shut it down immediately. Two of the belts had came off and made it overheat. It tried to turn over once but now won't start. Will that cause the motor to lock up?
Thank you James Myer for this useful post!
pllevine (07-17-2016)
  • Old 07-16-2016, 02:50 PM   #2
    Hunter12345's Avatar
    Status: Silver Contributor
    Gallery Images: 2
    Send Hunter12345:
    Default Re: Belt came off and overheated motor
    What year make and motor are u running?
    1998 shabah 180
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 07-16-2016, 10:07 PM   #3
    My Model: Z276
    Send Brian Belcher:
    Are you saying the starter can not turn over the motor or it turns but won't start ?
    Old 07-18-2016, 01:40 AM   #4
    My Engine: 5.8FSI S
    Send James Myer:
    The motor won't turn over. It got hot, it was making popping noises.
    Old 07-18-2016, 01:42 AM   #5
    My Engine: 5.8FSI S
    Send James Myer:
    1998 shabah 180
    5.7l 350 mag
    Bravo III
    1995 5.8 ford Volvo motor
    Old 07-18-2016, 12:24 PM   #6
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    You may have hydraulic lock caused by the over heat. The heads can warp slightly allowing cooling water into the cylinders. Try taking the spark plugs out of the motor. If you see any water come out of the plug holes then that is your problem. You need to get the intake and heads off ASAP, remove water, clean up the cylinders with WD-40 and replace the head gaskets with a good marine gasket.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-18-2016, 02:29 PM   #7
    My Engine: 5.8FSI S
    Send James Myer:
    I'm going to try that when I get off work. Thanks. I'll let you know the outcome.
    Old 07-18-2016, 10:43 PM   #8
    My Engine: 5.8FSI S
    Send James Myer:
    I pulled the plugs the only one had water in it. I cleaned everything up and put new belts on and it started right up and it didn't run hot. It ran for a while and the temperature stayed at 150. Looks like I got lucky. Thank you.
    Hunter12345 and Firestone like this.
    Old 07-19-2016, 05:25 AM   #9
    My Model: Z202
    Send Firestone:
    Good save James
    Firestone - 2000 Mariah Z202 5.7L MAG Alpha I Gen II
    James Myer likes this.
    John
    V Belt Repair Jimh23 Mercury MerCruiser 8 02-20-2013 03:46 PM
    Engine overheated dkwalls Original Mariah Talk 7 07-14-2009 10:00 AM
    Overheated..Please help! jasfiveo Original Mariah Talk 15 06-22-2009 06:37 PM
    Belt hell! Jason_Smith008 Original Mariah Talk 2 06-02-2009 02:09 PM
    Belt Pullies ronbeco13 Mercury MerCruiser 4 01-25-2008 01:19 PM
    There are 285 users
