My tow set up
Trailering and Tow Vehicles
Old 07-03-2013, 02:46 PM   #11
Default Re: My tow set up
I like the F150! I have a 1999 with 3.73 gears. I was looking at the 2012-13 and noticed they all seem to be running the 3.55 ratio. The only reason I can see that working for them is they now have a 6 speed tranny. Any ideas?
  • Old 07-03-2013, 03:11 PM   #12
    vman's Avatar
    vman is currently offline
    My Model: Z22 Talari
    My Engine: 7.4 Bravo III
    Gallery Images: 4
    Send vman:
    Those 3:55 gears won't even get out of their own way. I was going to trade mine in for a 2013 and the 5.0 version, but you can't find a truck with that motor, 3:73 gears and heavy tow package on the lots. Dealers aren't buying them. You have to order the truck from Ford to get that package. Of course when I bought my 2010 they only had a few out there and had to go to texas to get my truck. I have always had the 3;73 gears in my trucks and it pulls effortlessly my boats, and trailer filled with my motorcycles. My truck only has 32k on it, but was likeing the 5.0 but after some research it was rediculous to go through all that and have less of a truck. Its horrible what they have done to half ton trucks. They have turned them into glorified cars. Anymore you have to go up to a 3/4 or 1 ton truck to do the work a 1/2 ton used to do. My truck will pull or tow 11400 pds. I do have the 6 speed in mine as well. Its only used for towing now and just sits the rest of the time.
    Old 07-03-2013, 03:47 PM   #13
    vman's Avatar
    Gallery Images: 4
    Send vman:
    Here is a pic of my truck towing my champon. 20.1ft, with a built 200 merc black max last weekend , was heading to my place at the Lake of the Ozarks.http://
    Old 07-03-2013, 05:04 PM   #14
    That's a nice setup for sure.
    I had not read into the newer 5.0s an the gearing to get an understanding of if they even come with 3.73. I am aware that they come with the 3.55 to make the sticker on a new truck have a decent MPG rating... As it is they seem to do work. My uncle has the eco boost. Its very impressive. After a few years of having them on the road we can determine how impressive they really are in terms of longevity.
    Anyways, if it was such a big deal I suppose one could always have the gears changed for a price.
    Old 07-03-2013, 06:55 PM   #15
    V-side-down is currently offline
    My Model: 214 Jubilee
    My Engine: 5.7 LX , Alpha 1
    Send V-side-down:
    The least expensive way out I see is to put on a set of chains!!!
    Old 07-11-2013, 06:24 PM   #16
    nonwin1973 is currently offline
    My Model: Shabah 212
    My Engine: 350
    Send nonwin1973:
    Jet- I used to experience the same thing you went through. I had every suggestion thrown at me. But I stuck it out till I had to get new tires. It was suggested to me, to get AT tires for that very reason. I went with the BFG AT KO's. No more spinning and tires looked great. The thicker treads have more bite into the ground giving the truck more grip. Think of when you run the tips of your fingers across a sheet of ice (this is like a road tire tread tire), then when you run your fingers tips across the same sheet of ice with a little bit of your finger nails digging in (this is like a AT tire) lastly when you run just the tips of your fingernails across the sheet of ice (this would be your MT tires) good luck!
    Old 07-19-2013, 01:24 PM   #17
    raulston88's Avatar
    raulston88 is currently offline
    My Model: z212 shabah
    My Engine: 5.7L
    Send raulston88:
    Here's my tow setup,
    05 F-150 FX4, 4x4 SuperCrew, 5.4L, tow pkg w/3.73 gears. Does a decent job of pulling the 21 ft Shabah....
    Thank you raulston88 for this useful post!
    nglauer (07-22-2013)
    Old 07-21-2013, 03:36 AM   #18
    m&mmariah is currently offline
    Status: Gold Contributor
    My Model: 180 Shabah
    My Engine: 4.3 Mercruiser 4v carb
    Send m&mmariah:
    OK, this will be my first attempt at attaching a photo. If I'm doing it correctly, it should be a photo of our 1996 Shabah 180 hooked up to our 1993 GMC K3500 diesel pickup truck. It's parked in front of our condominium at Shaver Lake, CA. Well, here goes!
    Thank you m&mmariah for this useful post!
    nglauer (07-21-2013)
    Old 07-21-2013, 03:40 AM   #19
    Hey ,
    It worked!!
    But , need a better pic or two of the Mariah.
    Seen plenty of Chevys...sorry GMCs in my day.
    Just kindin'........glad you got it figured out.
    Old 07-21-2013, 04:32 AM   #20
    Send m&mmariah:
    OK Colorado, here you go!
    P.S..........Mikeyt, close your eyes when you look at the outdrive.
    There are 317 users
