Master cylinder on surge brake Repair/Replace?
Trailering and Tow Vehicles
Old 09-03-2008, 03:28 PM   #1
Z 202's Avatar
Z 202 is currently offline
My Model: Mariah Shabah 202
My Engine: 5.7L Alpha 1
Send Z 202:
Default Master cylinder on surge brake Repair/Replace?
I have a Dico (Titan) model 60 surge brake controller on my trailer, and it's not working. I've looked at replacements, but I was wondering if anyone has overhauled one of these. I've never done an overhaul on a master cylinder, but I'm no stranger to wrenching, and I have the tools. Just wondering if a full on replacement of the whole unit is the best plan, or whether or not I can rebuild the one I have.
Anyone with experience willing to share their thoughts?
My Mariah
  • Old 09-03-2008, 05:01 PM   #2
    lomitabob's Avatar
    lomitabob is currently offline
    My Model: 2001 Z250 Shabah 7.4LMPI Bravo I
    Gallery Images: 12
    Send lomitabob:
    I found replacement parts online including master cylinder rebuild kits and new master cylinders all reasonably priced by using Google "dico titan model 60". The choice to use a kit or replace is the amount of pitting inside the master bore and if you have the right size hone to clean the old master. Good Luck!
    Old 09-04-2008, 12:24 AM   #3
    Cj7
    Cj7 is currently offline
    My Model: 98 Mariah shabah 180 limited edition 4.3L
    Gallery Images: 1
    Send Cj7:
    Z 202, as lomitabob said you can get replacement parts for you surge. If you have any troubles getting parts or need part numbers let me know. I own a trailer shop here in Arizona. I can get you anything you need and throw in a 10% discount if your a Mariah Owners Club Member. Or direct you to somewhere close to where you live to get parts. Just PM me.
    cj7
    Old 09-06-2008, 03:52 PM   #4
    Z 202's Avatar
    Send Z 202:
    Well, I found a complete coupler at a local shop for $116! Slapped that puppy on last night, bled the brakes and I'm good to go. Thanks for all the replies, but in the end, I couldn't pass up on the time savings of just replacing the whole thing.
    If anyone in Southern Ontario is looking for a good price on the coupler or parts. Cerka Industries in Milton made my day!
    My Mariah
    Old 09-07-2008, 03:29 PM   #5
    Congrats Z202... I think that's the route I may have to do too, my coupler has started leaking brake fluid. I contacted Tie Down Engineering, who makes my coupler, and they suggested replacing the master cylinder, and won't cover it under warranty. I think it might actually be easier to replace the whole coupler instead of tearing the existing one apart to replace the MC. I figure I'll last the rest of the season on it, as I really won't be doing any serious towing.
    Z202, did you replace with a Dico brand again, or another make? I was wondering if they were somewhat universal.
    Cj7, I'll be in touch with you here in a few weeks!
    Old 09-08-2008, 01:18 PM   #6
    Z 202's Avatar
    Send Z 202:
    The replacement unit was a Titan, but it's identical to the Dico unit. The new one also has a lever lock on the coupler (to fit my 2" ball) whereas my old one had a "multi-fit" (rotating knob) lock, which was another reason I went with a full on replacement, as I prefer the lever lock.
    I figured a new master cyl. + shock damper + my time to disassamble/reassemble the unit was equal or greater than complete replacement, so that's the route I went. As you are looking at doing it over the winter, you might consider the tear down re-build route. I had no brakes on the trailer, so I getting things operational again was my first priority.
    I would have liked to take up Cj7 on his offer, but shipping + duty + courier fees to collect said duty would have put his prices above what I could get locally.
    My Mariah
    Old 09-09-2008, 03:56 AM   #7
    Cj7
    Gallery Images: 1
    Send Cj7:
    Noproblem I,m glad to help! Glad you found the parts you needed!! Sounds like you got a great deal.
    Cj7
    Brake Master Cylinder Removal cookscc Trailering and Tow Vehicles 7 05-30-2024 06:45 PM
    Master Cylinder for breaks turfguy99 Trailering and Tow Vehicles 1 07-29-2008 08:12 PM
    Need surge brake cap bpfirrman Trailering and Tow Vehicles 4 07-28-2008 04:45 PM
    replace windshield with plastic windscreen? Ultraboy Original Mariah Talk 0 04-29-2008 04:39 AM
    Replace/Refinish lock doors? Z275 Original Mariah Talk 6 10-03-2007 10:59 AM
    There are 430 users
