Strakes/Chines sit on top of trailer bunks
Trailering and Tow Vehicles
Old 09-16-2020, 09:40 PM   #1
TPMJR25's Avatar
TPMJR25 is currently offline
My Model: Z252 Shabah
Send TPMJR25:
Default Strakes/Chines sit on top of trailer bunks
I have a 1997 Mariah 252 Shabah. The trailer was not original to the boat. I knew that when I purchased, but did not realize until my first launch that the strakes/chines are riding on top of the wooden bunk as opposed to in between them when re-trailering. Was curious if this is an issue in regards to potential damage to the fiberglass strakes/chines, or if it will be ok without trying to reposition the bunks. I do see alot of boats/trailers that this occurs. Thanks for any feedback.
  • Old 09-17-2020, 01:18 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Strakes/Chines sit on top of trailer bunks
    Sitting on the strakes is probably not going to cause a problem for short term trailering. But if it sits for long periods of time you really want the load spread across the hull rather than a concentrated point load. The point load could slightly change the shape of the hull and decrease efficiency. Similarly, for trailering across rough roads, you want the load spread so it won't damage the hull.
    I would recommend you adjust your trailer bunks to fit the boat properly.
    TPMJR25 likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    TPMJR25 (09-17-2020)
    trailer bunks/strakes
    Trailer bunks Tlolesen Trailering and Tow Vehicles 4 07-30-2020 08:13 PM
    trailer bunks.. composite decking? phillycincykid Original Mariah Talk 7 06-02-2015 12:37 AM
    Trailer bunks for 202 Shabah candanewell Original Mariah Talk 5 04-14-2012 01:43 AM
    Trailer Bunks Talari95 Original Mariah Talk 1 08-03-2010 04:32 PM
    Trailer Bunks JohnZ202 Trailering and Tow Vehicles 8 12-28-2009 04:28 PM
    There are 375 users
