trailer bunks.. composite decking?
Old 05-25-2015, 01:54 PM   #1
phillycincykid's Avatar
phillycincykid is currently offline
My Year: 1990
My Model: xlc 2150
My Engine: 5.7 l mercruiser
Send phillycincykid:
Default trailer bunks.. composite decking?
when i was bleeding the surge brakes on the trailer the other day i noticed its time for the trailer bunks to get replaced.
Has anyone done this yet using the composite wood, like what you would use for decks? i don't know how it could be any worse then what is there, making sure there is nothing im missing with that stuff.
Mariah 1990 XLC 2150 5.7 V8 about halfway rebuilt.
  • Old 05-26-2015, 02:27 PM   #2
    baholtz is currently offline
    My Model: 202 Shabah
    My Engine: 305
    Send baholtz:
    Default Re: trailer bunks.. composite decking?
    Composites, as they are generally made out of some plastic blend, are commonly susceptible to creep. I would guess they would be stable but only if supported effectively. Also, I'm not sure what is out there that would fit dimensionally.... I don't know that I've seen 2x4 composite materials.
    Old 05-26-2015, 08:46 PM   #3
    My Model: 180 Diablo
    My Engine: 3.0 Mercruiser
    Send TN_Diablo:
    Consider that when using composite decking it is often suggested you tighten joist spacing especially on things like stair treads. 12" rather than 16". I think composite boards would be too flexible and not support as well as wood.
    Old 05-27-2015, 12:12 AM   #4
    My Year: 1990
    My Model: xlc 2150
    i took the flexing into consideration, there are only certain locations on the trailer to reattach. since im not a welder, i cant add any supports. I'm thinking i'm just going to go back with wood. it has worked for 10 years.
    Old 05-31-2015, 03:15 PM   #5
    Txtruckerpaul's Avatar
    My Model: Z240 talari
    My Engine: 7.4 bravo III
    Send Txtruckerpaul:
    What kind of wood is best for these? I need to replace mine soon
    Old 06-01-2015, 06:59 PM   #6
    Send TN_Diablo:
    I would find the clearest, straightest grain piece of pressure treated lumber matching your existing bunk boards. It is probably PT now. Remember to use all galvanized or SS hardware on PT lumber.
    Old 06-01-2015, 11:16 PM   #7
    My Engine: 305
    Send baholtz:
    Straight pressure treated is an oxymoron!
    You could also go redwood.
    Tn_diablo is likely right.
    Old 06-02-2015, 12:37 AM   #8
    My Year: 1990
    My Model: xlc 2150
    stainless steel connectors is the most important. the last person who replaced the bunks on my trailer felt stainless steel screws weren't worth the money. now i own the problem
    1994 Z212 bunks trailer mihatran Original Mariah Talk 14 06-13-2013 10:19 PM
    Trailer bunks for 202 Shabah candanewell Original Mariah Talk 5 04-14-2012 01:43 AM
    composite Hull jktbea Original Mariah Talk 2 08-06-2010 10:56 PM
    Trailer Bunks Talari95 Original Mariah Talk 1 08-03-2010 04:32 PM
    Trailer Bunks JohnZ202 Trailering and Tow Vehicles 8 12-28-2009 04:28 PM
    There are 281 users
