2000 250 Shabah
Trailering and Tow Vehicles
Old 03-08-2017, 10:17 PM   #1
Jmkhiggs is currently offline
Send Jmkhiggs:
Default 2000 250 Shabah
I'm looking into buying this boat, but I don't know if my half ton can drag it. Does anyone know the tongue and towing weight of this little beauty?
  • Old 03-08-2017, 10:33 PM   #2
    tbrookens's Avatar
    tbrookens is currently offline
    My Model: Shabah Z252
    My Engine: 454 Mag, Bravo 3
    Gallery Images: 2
    Send tbrookens:
    Default Re: 2000 250 Shabah
    My Z252 weighs 4,800 lbs, empty. I don't know the tongue weight, or the weight of the trailer.
    Tracy Brookens
    Thank you tbrookens for this useful post!
    Jmkhiggs (03-08-2017)
    Old 03-08-2017, 11:45 PM   #3
    Send Jmkhiggs:
    Thanks. I got the seller on the phone and he shipped it with the trailer at just under 5500 lbs. that's well within my truck's tow weight.
    I can't wait to pay the man and get this little beast over the side!
    Thank you Jmkhiggs for this useful post!
    1996 Mariah Z252 (05-13-2017)
    Old 03-08-2017, 11:59 PM   #4
    I have a half ton. I also have a Shabah 250 with a 7.4 mpi. I have weighed the truck and trailer and came up with 6700 for the boat and trailer at a local landscape business. My truck is a 1999 F150 5.4 with a 3.73 rear end. It has a tow rating of 7800 max and a GVWR of 6300. ( If I recall correctly. Been a while since I looked at the numbers on the truck.)
    I can give you my thoughts on towing said boat with my half ton. I live in Colorado and purchased the boat in Arizona. It was an 11 hour drive to Az and it was around 16 hours home. It took 5 extra hours to drag the boat behind my old half ton. I would not do it again knowing what I know now. (Trailer did NOT have working brakes at the time!!) My poor little truck hated it. A little over 20mph up Raton pass and right around 55-60 as a comfy speed on open road. This trip was in February when it was freezing outside- no problems getting hot. I still use this truck to pull the boat all the time! The lake we visit is under ten min from our house and only has a 45 mph speed limit for a brief portion. It does that no problem.
    We had a 2010 GMC 1500 Z71 with the 5.3 vortec 3.55 rear end for two summers. It towed this boat pretty good. We would average 14 MPG at 65mph which was better than my buddy towing his 21' boat behind his 2008 duramax. He was getting 13 mpg with a smaller boat and same speed. We made the 12 hour trip to Lake Powell with that truck and it didnt put up much of a fuss until with hit some of the high mountain passes. It really did not do bad. Just a naturally aspirated engine at altitude.
    Thank you Motoxxx43 for this useful post!
    Jmkhiggs (10-24-2020)
    Old 03-09-2017, 12:05 AM   #5
    I have since put new axles, electric brakes and load D tires on the trailer. Those items made a big difference in ease of towing and stopping. Something to consider if you are buying a 15 year old boat- my trailer needed much more work than my boat did.
    What year is the boat/trailer?
    Old 03-09-2017, 12:08 AM   #6
    Send Jmkhiggs:
    I've got a 2014 chevy 1500 4 x 4 with tow package so I believe I'm good up to 6800 lbs. I'm so fired up about this boat! The trailer is original to the boat, 2000, but stored indoor and both have been very well maintained
    Old 03-09-2017, 12:10 AM   #7
    I really enjoy this 250! It's not a speed boat but it is a fun boat for sure!
    What motor do you have in yours? I hope I didn't fudge up the math when I weighed my boat/trailer.
    Sent from my XT1585 using Tapatalk
    Old 03-09-2017, 12:17 AM   #8
    Send Jmkhiggs:
    It's the 7.4 merc
    Old 03-09-2017, 12:18 AM   #9
    Send Jmkhiggs:
    How's the ride in chop?
    Old 03-09-2017, 12:20 AM   #10
    I cant see a 1200lb difference even if there was a full tank in the boat and it was loaded down (which it was not). Thanks for the info. Welcome to MOC!
    2000 250 Shabah VS 2000 Z250 Shabah Mhilly Original Mariah Talk 5 04-01-2015 08:00 PM
    2000 182 Shabah ColoradoDiablo Mariah Boats For Sale & Wanted 1 03-16-2014 04:44 PM
    2000 20' Shabah jherbert Introductions 5 05-25-2010 02:59 AM
    2000 258 Shabah mfitz62 Introductions 4 07-05-2009 03:12 PM
    2000 182 Shabah donnae Original Mariah Talk 4 08-22-2007 11:05 AM
    There are 311 users
