Question regarding cross-country tow
Trailering and Tow Vehicles
Old 05-01-2008, 05:36 PM   #11
Another option, check out http://www.uship.com
It's a site for locating freight transporters. The way it works is you basically post some information about it, then companies offer bids for transporting it to you! You could always give that a try while you try and locate a buddy with a truck!
  • Old 05-01-2008, 08:13 PM   #12
    Ok....i'll think outside the box here. How 'bout a 'drive her home' trip? Let's see now, up the east coast, the Hudson, the Erie canal, Lake Erie, St. Clair, Michigan (Green Bay) or even Superior (Duluth) ?? Not practical i know but i liked the idea....
    Old 05-02-2008, 01:47 PM   #13
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    I'm with Mike - have the wife drive the Tahoe and empty trailer back (that's easily within the tow limits!) while you take your time on the new boat!!!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 05-02-2008, 02:15 PM   #14
    Tvacek's Avatar
    Tvacek is currently offline
    My Model: 2000 Mariah Z278 Shabah, 496 HO Mag Bravo III
    Gallery Images: 10
    Send Tvacek:
    If I could make that work, that would be the coolest trip home EVER......
    To answer your earlier questions, I do have the 5.3 liter...unfortunately the tahoe isn't available with the 6.0 liter. I do have the high-end towing package (minus the electric brakes) & transmission cooler.
    I've looked into a weight distribution hitch but it sounds like this will not work with surge brakes.
    Old 05-02-2008, 03:11 PM   #15
    I will tell you, I made the trek from Baltimore back to Cincinnati with a 5.3L. However my boat is a slight bit lighter, and I was still 200lbs over the max rating. The Pennsylvania moutains are a killer, I averaged about 25mph up each one and was running sometimes in 2nd gear. I'm sure there's been improvements to the engine and transmission since the 1999 model I used, but I honestly would not recommend it, especially for towing through the hills.
    Like a lot of people have pointed out, it's probably not a good idea to tow it long distances with your Tahoe. I'd spend a little money and get it professionally towed to you. I checked the estimator on Uship and it's estimating anywhere from $1500 - $2900 for delivery. If this is within your budget (and it should be since you got such a steal on the boat!) this would be the way to go. Now, if you're running into some issues with transport, PM me, I might be willing to try and help you out... I've got a 3/4 ton Excursion V10. Maybe I could pick it up and meet you at the Ohio & Indiana border. It'd be a pretty flat tow back to Omaha from here...
    Old 05-02-2008, 06:58 PM   #16
    Tvacek's Avatar
    Gallery Images: 10
    Send Tvacek:
    A co-worker sent this to me.
    "You don't need a tahoe to get that boat..."
    Old 05-03-2008, 03:43 AM   #17
    Hey Tvacek,
    Yea, I have some friends who believe everything they see too....
    Got to admit, it does looks impressive with the Ridgeline pulling that load until you find out the Spectre only weighs 2700lbs....
    Spectre 30' Catamaran Specifications :
    Centerline Length - 30'
    Beam - 105"
    Hull Type - Catamaran
    Deadrise at Transom - 17.5º
    Weight - 2200 lbs (OB) 2700 lbs (IO)
    Old 05-03-2008, 04:20 AM   #18
    Tvacek's Avatar
    Gallery Images: 10
    Send Tvacek:
    OOPS...... Apparently my humor isn't widely appreciated.... Guess I should have done my homework!!!
    Hey Tvacek,
    Beam - 105"
    Old 05-03-2008, 02:54 PM   #19
    Mariah Z276's Avatar
    Mariah Z276 is currently offline
    My Model: 1997 Z276 7.4L Bravo III
    Send Mariah Z276:
    I pull my Z276 with a F350 duelley. I cant imange even usinfg a 3/4 ton. I just pull to and from the lake. Across country with a 1/2 ton out of the question for me. You really should reconsider and get a bigger truck.
    Butch Eigenbrod
    1997 Z276 7.4L Brovo III
    Cape Girardeau MO.
    Old 05-03-2008, 10:27 PM   #20
    WolfProperties is currently offline
    Not sure where you are from, but the transport company I used (we use them for all our RV's) was very reasonable. I think hes around $1.50/mile loaded.
    1999 Z280 7.4l BIII
    Matching Prestige Trailer
    Upholstery Question jmills224 Original Mariah Talk 16 09-25-2015 04:47 PM
    A/C Question WolfProperties Original Mariah Talk 6 05-07-2008 12:56 PM
    Flo Torq II question 180diablo Prop Talk 6 04-04-2008 02:22 PM
    question about shifting 180diablo Mercury MerCruiser 0 07-24-2007 09:58 PM
    There are 251 users
