Quicksilver 3000 Throttle assembly
Old 07-29-2009, 12:04 AM   #1
crogers is currently offline
Send crogers:
Default Quicksilver 3000 Throttle assembly
The plastic on the bottom has cracked and seperated . The rubber cover over the travel trim can now potentially fall out . Where are the replacement parts for these . I have searched the net with no success . Any one ? Shabah 212
  • Old 07-29-2009, 06:48 AM   #2
    WetWilly's Avatar
    WetWilly is currently offline
    Status: INACTIVE
    Gallery Images: 25
    Send WetWilly:
    Default Re: Quicksilver 3000 Throttle assembly
    Hi crogers,
    I replaced the upper and lower one 2 years ago. You can visit your local Mercruiser parts supplier and he should be able to order you the lower plastic face plate or you can order it from an on-line store.
    If your controller looks like this one:
    I found this QuickSilver parts breakout and parts price list on-line from Doug Russell Marine:
    The lower face plate (Cover Assembly_Bottom) is highlighted in yellow on the parts list, As there are two listings and I'm sorry, but I can't remember which one it was, so ask which one comes with decal #16 (Quicksilver 3000) already installed and that's the one you want.
    Click here to go to Doug Russell Marine's web site.
    If your controller is different, they should still be able to order you the parts you need.
    Good luck,
    WetWilly
    Thank you WetWilly for this useful post!
    Firestone (05-26-2016)
    Old 07-29-2009, 08:56 PM   #3
    midwest mariah's Avatar
    midwest mariah is currently offline
    My Model: 1996 MX180 Shabah 3.0L Alpha 1
    Send midwest mariah:
    awesome stuff here Willy I'm gonna hijack this post for a second.
    my throttle is a bit sticky, that is not smooooth once in gear, you cannot steadily increase throttle. it jumps from 1200 to 2200 rpm. If you tap the throttle just a little bit, you can move up slowly. Is there possibly something in this control that would cause this, or is it in the linkage?
    Thank you midwest mariah for this useful post!
    BeaucheneLloyd (02-12-2015)
    Old 07-29-2009, 09:34 PM   #4
    Send crogers:
    Thanks again wet willy , you are two for two . Really appreciate the info , order has been placed .
    Thank you crogers for this useful post!
    Old 07-29-2009, 10:28 PM   #5
    WetWilly's Avatar
    Status: INACTIVE
    Gallery Images: 25
    Send WetWilly:
    Hi midwest mariah,
    I would disconnect the throttle cable from the controller and see if the controller is still stiff. If it's now smooth, disconnect the other end of the throttle cable and check for any binding at the linkage or carb/throttle body. I suspect it's the cable as the lube inside dries out over time or gets gummy as moisture gets into it and causes corrosion as well.
    Good luck and keep us posted on what you find.
    WetWilly
    BeaucheneLloyd likes this.
    Old 07-30-2009, 01:11 PM   #6
    I'll give that a shot and see what I find, thanks for the info!!
    Old 08-03-2009, 12:36 AM   #7
    vkrishan is currently offline
    My Model: 1994 Z225 Davanti 5.7L Merc Bravo III
    Send vkrishan:
    Where can we find out which control cable to replace?
    Quicksilver Keyless Pad thawk Original Mariah Talk 4 07-06-2012 01:59 AM
    mercruiser 3000 control jgreen Original Mariah Talk 0 07-21-2009 05:24 AM
    Throttle Arm assembly? trussman Original Mariah Talk 1 07-07-2009 12:08 PM
    Wanted: Transom mounted paddlewheel assembly WetWilly Mariah Parts For Sale & Wanted 4 03-13-2009 08:36 AM
    Total Members: 18,527
    Total Threads: 12,958
    There are 110 users
