Thru-hull conversion.
Old 07-30-2009, 12:45 PM   #1
doofusmarine is currently offline
Send doofusmarine:
Default Thru-hull conversion.
Hello,
I have a 1995 Talari 24 with the 5.7merc/alphaone setup. I wish to convert to the mercruiser "closed loop" cooling system .
I don't know where to position the Apollo thru-hull.??.
I would be grateful for any help on this conversion.
I am also looking for:
A good 3-step ladder for this boat...
Owners manuals...
Side stripeing....
Thank You,
Geoff
  • Old 08-01-2009, 12:10 AM   #2
    Default Re: Thru-hull conversion.
    Hi doofusmarine,
    Not sure what the "Apollo thru-hull" is but it sounds like the seawater pickup for an inboard motor system. The I/O setup uses the same syeup as the non-closed system with the exception of a water to water heat exchanger. The water that circulates through the motor is in the "closed" side and seawater is brought through the Alpha drive to the heat exchanger then out through the exhaust manifolds.
    I am also looking for: A good 3-step ladder for this boat...
    The Ladder - See this thread, your ladder and mine should be the same so read the #4 post, click here.
    Owners manuals...
    Owners manual - We have a '94 and '96 Owners manual in literature section, they are basically the same, the talk about some of the functions aboard the boat, they're not model specific and they deal more with boating rules and safety. To access them, you need to be a contributing member, click here to see what each lever offers. This will also give you access to all documentation, service/repair manuals and wiring diagrams, company history, etc.., trust me when I say this is the second best thing you can do for your Mariah, joining the club was the first!
    Side stripeing....
    We have a club member - 95 Z240 Talari, he has many of the graphics for the 97 and up Mariahs hull shield decals and gold "Mariah" script decals, he is currently going through his inventory to see if there are any older hull graphics available. I myself hope to hear good new from him soon as your Talari and mine share the same graphics and ours is a little messed up...
    Thru Hull Transducer 300sflyer Original Mariah Talk 4 09-28-2010 02:20 PM
    Stress fractures in hull dudders Sea Fox - Mariah Talk 6 06-24-2009 01:06 PM
    Barchetta Hull Design boarder1010 Original Mariah Talk 8 07-08-2008 06:20 PM
    Roadrash on the hull help Banson41 General Maintenance 2 05-26-2008 12:54 AM
    hull repair bpfirrman General Maintenance 5 04-30-2008 02:31 AM
    There are 322 users
