after market 4 barrel carb.
Sea Fox - Mariah Talk
Old 01-29-2012, 11:13 PM   #1
schevel's Avatar
schevel is currently offline
My Year: 2006
My Model: sx21
My Engine: 5.0L
Send schevel:
Default after market 4 barrel carb.
I just bought a 2006 sx21 from my friend, and he had a new intake and holly 600 carb. installed. I have actually put more hours on the boat than he has for the last 2 years, and I have noticed a back fire through the carb. once and awhile. I think the mechanic installed the distributor 1 tooth off. My question is, will this carb. damage the engine? Now that I have ownership of the boat, I want to fix the timing, but not sure how to tell which way to rotate the distributor. Any suggestions? He has also given me the original intake with 2 barrel, maybe I should just put it back on.
  • Old 02-04-2012, 11:03 PM   #2
    Minnox's Avatar
    Minnox is currently offline
    My Model: Z 235 Talari
    My Engine: 5.7L Bravo III
    Send Minnox:
    Default Re: after market 4 barrel carb.
    You need a timing light to do the job properly. You can loosen the bolt on the distributer and turn it either way with the motor running and if you have the ear for it you can tell when it is running better but this is not the proper way to do it. The timing needs to be set using a timing light and if you are still having a problem then the carb may be to big for the motor.
    Mike
    1996 Z235 Talari 5.7L Bravo III
    Upper Chesapeake Bay Is My Playground!!!
    Old 02-08-2013, 02:14 AM   #3
    Booberry is currently offline
    My Year: 2006
    My Model: 25sx
    My Engine: 5.0l
    Send Booberry:
    you can also change the jets in your carb. This wil not do anything for the timing, but can help with the backfire if you are getting to much fuel.
    Honestly, if you are asking questions about timing, you might want a mechanic to teach you how to set points, distributor caps, and use a timing light. It is becoming a lost art.
    Old 02-08-2013, 02:35 AM   #4
    No points in that engine package!
    Questions is what this site is all about
    Old 02-08-2013, 03:03 AM   #5
    And....this thread is over a year old.
    Nada Price vs Market nhorton123 Original Mariah Talk 2 12-27-2011 05:51 PM
    After Market Camshaft buchshot12000 Projects 0 08-13-2011 11:18 PM
    in the market for another Mariah John Miller Original Mariah Talk 8 06-20-2011 05:29 AM
    Mariah PC Talari 240 Limited Edition 1998 on the market.. sweetdreams Mariah Boats For Sale & Wanted 0 10-30-2010 09:11 PM
    4 barrel carb or not MariahMX20 Projects 6 04-20-2008 11:56 AM
    There are 267 users
