Running Stern Drive 4.3 on land
Sea Fox - Mariah Talk
Old 05-25-2011, 04:25 PM   #1
canadamariah is currently offline
Send canadamariah:
Default Running Stern Drive 4.3 on land
I want to start up my 2004 4.3 mercruiser (19ft sx9) stern drive on land. This is my first boat and I was told to put the ear muffs over the inlet holes on the stern drive. Problem is I don't know where the inlet holes are. I assume once i cover these holes and hook up the water hose I can then start it up and run it for a few minutes. It was professionnally winterized and I was told I can just turn the key and start it up. I checked the oil. Is there anything else to check. I wanted to try it before I put it in the water.
  • Old 05-25-2011, 04:45 PM   #2
    Default Re: Running Stern Drive 4.3 on land
    Water intake is just below the cavitation plate on both sides. Earmuffs on, turn water on, start engine, do not over-rev, do not run for more than 2-3 mins.
    Old 08-13-2011, 04:05 AM   #3
    m&mmariah is currently offline
    Status: Gold Contributor
    My Model: 180 Shabah
    My Engine: 4.3 Mercruiser 4v carb
    Send m&mmariah:
    mikey, why no more than 3 minutes? At the end of the boating season, I run mine a lot longer on the muffs to warm up the oil prior to oil change, so that the oil drains easier. What's the harm in longer than 3 minutes? Also, what are our engines supposed to run temp wise? Seems like whenever we're running about 2800 rpm for an extended period, temp maxes out at about 150. Think I need a new thermostat? Appreciate your knowledge on all this stuff.
    Mark & May.
    leak in stern drive tem Original Mariah Talk 1 05-12-2011 08:30 PM
    Stern drive position while trailering? pincourtmariah Trailering and Tow Vehicles 8 07-31-2010 10:09 PM
    Change stern drive lube Dogloop General Maintenance 6 06-01-2010 03:05 PM
    Check Your Stern Drive Alignment! Z280Bob Original Mariah Talk 0 11-02-2009 08:51 PM
    Stern drive refinishing ideas needed. bblauvelt Mercury MerCruiser 3 10-28-2008 10:10 PM
    There are 217 users
