Change stern drive lube
General Maintenance
Old 05-28-2010, 12:20 AM   #1
Dogloop is currently offline
My Model: 1995 Mariah Talari 210 5.0 LX\V8 Alpha One
Send Dogloop:
Question Change stern drive lube
Going to change the stern drive lube, but all directions say to remove vent screw and remove lower screw and let drain. I have a 1995 Mariah Talari 210 with the 5.0 LX motor, it does not have a lower screw. At least I am unable to locate one. I have looked all over, both sides and even removed the prop and checked there. It has the remote reservoir, but no drain screw. Am I missing something or can someone tell me how I am supposed to go about changing this. I don't want to screw it up, thanks for any and all replies.
  • Old 05-28-2010, 01:00 AM   #2
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    Default Re: Change stern drive lube
    What brand and model of stern drive do you have?
    IowaWing
    Steve
    Thank you IowaWing for this useful post!
    Dogloop (05-29-2010)
    Old 05-28-2010, 01:26 PM   #3
    Send Dogloop:
    Sorry its a Mercruiser Alpha One.
    Thanks!
    Old 05-28-2010, 05:10 PM   #4
    1stDave's Avatar
    1stDave is currently offline
    My Model: Z275 Shabah
    Gallery Images: 3
    Send 1stDave:
    It should be on the Starboard side of the lower unit, just above the skeg, on the bottom side of the bullet.
    HTH
    Thank you 1stDave for this useful post!
    Old 05-28-2010, 09:21 PM   #5
    Send IowaWing:
    Starboard?
    Mine is on the Port side on the bottom side of the "bullet".
    IowaWing
    Steve
    Old 05-30-2010, 05:16 PM   #6
    Send Dogloop:
    Yeah mine was on the port side as well, but I hadn't look that far down. It's really on the bottom of the bullet, I had thought it would be on the side, but you actually have to look on the bottom. I looked all over that that thing, but never looked on the bottom until this post.
    Old 06-01-2010, 03:05 PM   #7
    1stDave's Avatar
    Gallery Images: 3
    Send 1stDave:
    On mine it's on the starboard, glad you found it though, you also have a drain on the upper unit.
    Pump new gear oil in from the bottom drain until it comes out the top drain, this will push out any air.
    Put the plug back in the top drain then continue pumping til lube is visible at the reservoir.
    Put the bottom drain back, wipe up the stinky mess and top off at the reservoir.
    Drive Lube Monitor bigmolilmo Mercury MerCruiser 2 05-20-2010 06:39 PM
    Check Your Stern Drive Alignment! Z280Bob Original Mariah Talk 0 11-02-2009 08:51 PM
    Drive lube oil Brian Boating 101 15 08-10-2009 12:19 AM
    Steering Lube jakejorgenson General Maintenance 1 01-27-2009 03:25 PM
    Stern drive refinishing ideas needed. bblauvelt Mercury MerCruiser 3 10-28-2008 10:10 PM
    There are 324 users
