94 Davanti 225 Side storage compartment
Old 07-08-2009, 05:42 PM   #1
skaters is currently offline
My Model: 1994 Davanti 225
Send skaters:
Default 94 Davanti 225 Side storage compartment
Looking for one of the plastic facings for the side storage compartment. Thanks!
  • Old 07-09-2009, 06:39 AM   #2
    Default Re: 94 Davanti 225 Side storage compartment
    Hi skaters,
    Aren't these made from smoked Plexiglas? If so, look up ay plastics fabricator in your area and they should be able to cut, drill and polish it for you. The originals were made in-house and are not available anymore.
    Good luck,
    Old 07-09-2009, 05:07 PM   #3
    Send skaters:
    OK- Hopefully can find a fabricator willing to take on a small job. Thanks!
    Old 07-10-2009, 01:32 AM   #4
    Hi skaters,
    If you don't have any luck, we have one here called Tap Plastics and if you send me the dimensions (LxWxD and thickness and color - smoked or solid back), I can see if they can make one up and how much it'll be. They also do edge polishing and hole drilling if you want it.
    I had them make new plastic rails for our front seat mesh pockets (still have the protector paper on the new pieces):
    Old 07-10-2009, 06:25 PM   #5
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    It's actually possible to do things like this yourself, but the cutting and drilling is tricky.
    For the cutting, a regular table, radial-arm, or sliding-table miter saw will work. The trick is to get the right blade (IIRC, we used to use carbon-tipped finish blades), then move neigher too fast (chipping) or too slow (burning, melting) during the cut. Oh, and cutting this stuff really dulls saw blades rapidly. Cleaning up the edges is easy.
    Drilling has to be done with a spade bit with spurs, bullet pilot point or spur point bit to avoid chipping and cracking. Same thing applies as with cutting: Too fast and the plastic will chip/crack. Too slow and it'll deform.
    Back in the day, place I worked at, we cut and drilled all our own plastics.
    Jim
    '99 Shabah; Water in floor compartment Hausfam General Maintenance 6 08-30-2009 03:02 PM
    Side Panel removel jeffryb Original Mariah Talk 2 04-12-2009 12:55 PM
    Storage compartment collects water sweetdreams Introductions 6 11-14-2008 04:42 AM
    Side covers for the Bimini Top bakdraft Sea Fox - Mariah Talk 7 11-05-2008 10:16 AM
    Rear Seat Compartment drain boarder1010 Original Mariah Talk 9 06-09-2008 04:19 AM
    Total Members: 18,994
    Total Threads: 13,326
    There are 307 users
