'99 Shabah; Water in floor compartment
General Maintenance
Old 07-07-2009, 04:04 AM   #1
Hausfam is currently offline
Send Hausfam:
Default '99 Shabah; Water in floor compartment
Hi everyone. We own a 99 Shabah 180. We're only into our 2nd boating season ever...so I'm sure this is a dumb question. This weekend I noticed 2-3 inches of water in the center floor storage compartment of the boat. This isn't rain water...boat stays covered and on the trailer. I also pulled the plug last weekend and drained whatever water was already there. (and yes, the plug was put back in This water accummulated only after 2-3 hours on the lake. I don't know much about bilge pumps, so I know I'll need to check that first. The dashboard has a bilge switch. Should this be on all of the time ? Any other suggestions on things that I should check ? Thanks in advance for your advice...
  • Old 07-07-2009, 04:18 AM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: '99 Shabah; Water in floor compartment
    No, first you need to find out how the water's getting in. That shouldn't be happening.
    No. Only when you want to manually run the bilge pump.
    Jim
    Old 07-07-2009, 05:31 PM   #3
    mariah bob is currently offline
    My Model: 1996 200 Shaba Limited Edition 5.7 Alpha One
    Send mariah bob:
    your front under seat cooler drains into that compartment, but that is a lot. make sure the drain between the compartment and the engine well isnt cloged, it should all drain back to the back for the bilge pump to take care of
    Old 07-08-2009, 03:55 AM   #4
    SEMIJim's Avatar
    Send SEMIJim:
    LOL! I wondered why that "storage compartment" wasn't carpeted, like the others, and why it had a drain in it! It's a flippin' cooler!
    Lord, I'm slow sometimes.
    Drains right into the bilge via the ski locker, eh? Well, I suppose that won't hurt the metal-and-plastic oars or boat hook I've got in there.
    Jim
    Old 07-10-2009, 12:17 AM   #5
    94z190talari's Avatar
    94z190talari is currently offline
    My Model: Z190 Talari
    My Engine: 4.3LX
    Gallery Images: 12
    Send 94z190talari:
    Jim
    You need to prop that lid open when you leave the boat or it will get a little slimy! My ski storage compartment has never drained very well. Even had the dealer try and unclog it but it still sits in that compartment.
    Old 07-10-2009, 01:28 AM   #6
    dmg5606's Avatar
    dmg5606 is currently offline
    My Model: 1996 Mariah Shabah 4.3 180
    Send dmg5606:
    dont know bout other models, but my 96' shabah cooler drains out tha side of tha boat. that much water in tha boat i would be checking towards tha back of the boat. garboard seal , boots etc... i would check and see if tha float switch works on the bilge pump if your has it. just my 2 cents
    David & Diana Gibson
    Old 08-30-2009, 03:02 PM   #7
    gjackson78 is currently offline
    My Model: 2001 202 Shabah 5.0 Merc Alpha I
    Send gjackson78:
    We've had similar problems on our 2001 202 Shabah as well. Believe everyone when they say it can get real skunky/slimy.
    Floor Drain Problem Douglas Alderman Original Mariah Talk 8 07-13-2010 01:45 PM
    Floor Provo Projects 7 03-26-2009 07:28 AM
    Storage compartment collects water sweetdreams Introductions 6 11-14-2008 04:42 AM
    Core fillled floor attebury20 Original Mariah Talk 3 09-26-2008 07:53 PM
    Rear Seat Compartment drain boarder1010 Original Mariah Talk 9 06-09-2008 04:19 AM
    There are 240 users
