Rear Seat Compartment drain
Old 06-04-2008, 04:31 AM   #1
boarder1010's Avatar
boarder1010 is currently offline
Send boarder1010:
Default Rear Seat Compartment drain
I have a 182 Barchetta with the opening seat compartments in the back. There is a white plastic grommet type fitting in a hole at each end which theoretically should be water drains. However they are just pushed into the carpet and don't go anywhere? I don't like the idea of drill a new hold there as I don't know what is beneath? What are my options?
Kurtis
1995 182 Barchetta
  • Old 06-07-2008, 03:38 AM   #2
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Since I store mine in a garage, I flip the seats up and let the carpet dry out when I put it away.
    Old 06-07-2008, 02:19 PM   #3
    Mine has a rubber grommet in the hole & yes it drains onto the carpet then into the bilge. I wuz thinking though that i could pick up a thru hull drain thingy of some sort, remove the grommet & install the drain then attach a short piece of tubing so any water would go directly into the bilge.
    Old 06-07-2008, 08:23 PM   #4
    Send boarder1010:
    Is it ok to jus drill through where the plastic/rubber grommet is? Mikeyt when you say yours drains into the carpet then into the bilge, what do you mean. How is it getting to the bilge without a drain?
    Kurtis
    1995 182 Barchetta
    Old 06-07-2008, 10:37 PM   #5
    Mine has the 2 small 'jump' seats in the back next to the engine. Where the drain is located it simply drains onto the carpet next to the bilge area & slowly flows to the bilge given the slight tilt in the floor in that area.
    That whole area on mine tilts forward so that you can access the floor area beneath anyway so it's an easy job to change the grommet for a drain of some sort that you could attach a plastic tube to.
    Old 06-08-2008, 12:45 AM   #6
    Send boarder1010:
    Ok. Does anyone have the 3 flip up style seats accross the back that can tell me what the best course of action is? It is all one compartment under the seats but there has to be a way to get the water out as it comes in?
    Kurtis
    1995 182 Barchetta
    Old 06-08-2008, 04:31 AM   #7
    MariahPD is currently offline
    Send MariahPD:
    The plastic drains you are talking about are called plastic thru hull drains. The water will drain from the bench base then onto the carpet and the into the keel where it will drain into the bilge. Then it is up to you if you keep the brass plug out of the transom or use the bilge pump to remove the water from the bilge. Mariah used this set up for almost all of the super sport models and it was flawless.
    Old 06-08-2008, 03:02 PM   #8
    Send boarder1010:
    I don't fully understand. The water just soaks into the carpet inside the plastic drains and then seeps through to the bilge area? I always remove my plug to remove the water. The main reason I am asking this question is that I recently removed my boat from storage and did a very extensive wash including a light pressure wash of the carpet. When I washed under the seats the water just pooled at the end the boat was tilted to and it seemed to take forever for it to go away. In the end I was assuming the water had finally just soaked into the carpet and now needed to evaporate or dry.
    Kurtis
    1995 182 Barchetta
    Thank you boarder1010 for this useful post!
    Atec (09-05-2011)
    Old 06-08-2008, 07:55 PM   #9
    Send MariahPD:
    The water will drain to the bilge trust me, you will need to have the trailer sitting tounge high for all of the water to run to the bilge. Always remember that nothing beats sunlight and fresh air to prolong a boats life by keeping everything dry.
    Old 06-09-2008, 04:19 AM   #10
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    When I know the carpet is wet under the bench seat, I use a small block of wood to prop the seat forward just enough to let air get to it until it dries out.
    Thank you Paul F for this useful post!
    Atec (09-05-2011)
    Boat seat pedestals mikeyt Original Mariah Talk 17 02-03-2011 08:34 PM
    Floor Drain Problem Douglas Alderman Original Mariah Talk 8 07-13-2010 01:45 PM
    Wanted: Drain Sink Strainer Douglas Alderman Mariah Parts For Sale & Wanted 0 04-29-2008 03:50 AM
    New seat for my son 215Talari Chit Chat/Off-Topic 10 08-26-2007 03:29 PM
    For Sale: Mariah Seat ShabahZ280 Mariah Parts For Sale & Wanted 1 08-14-2007 12:19 AM
    There are 362 users
