98 shabah 255 propeller question
Prop Talk
Old 05-30-2012, 12:45 AM   #1
cudaah is currently offline
Send cudaah:
Default 98 shabah 255 propeller question
Recently picked up a 98 Shabah z255 with a 7.4 bravo III. I am having an issue with the boat leaning down on the right side quite a bit. It starts as soon as I get moving until I am almost running all out. By running all out still has a lean but not as bad. Doesnt matter if I am loaded with people or just my wife and I. Both props are 28 pitch and I run at 4K trim down but once I adjust the trim I run close to 4200. Should I try a 26 pitch? I read I should be 4200-4600 full throttle. Would that possible level things out? I had a four winns that seemed to lean and it seemed once I changed the prop it was much better. Any other things I could try besides prop or trim tabs? Thanks
  • Old 05-31-2012, 02:50 AM   #2
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: 98 shabah 255 propeller question
    The lean is called "Listing." All boats do it a little due to the engine torque. Mine did it to the left when I bought it (but I have a single prop).... It had a whale tail on it, and when I removed it it seemed to stop. When a dropped my prop pitch it seemed to help it a little more. Sounds like you are overpropped, but those BravoIII props are quite pricey!
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 06-01-2012, 04:39 PM   #3
    tmonson's Avatar
    tmonson is currently offline
    My Model: 1999 Z272 Shabah,
    My Engine: 7.4L Bravo 3
    Send tmonson:
    Are the batteries located on the rh side in the rear? Mine were on my Z272 and it did the same thing. I relocated the batteries to the Lh side and it resolved the issue. With the weight of me and both batteries it was enough to roll it to that side.
    214 Jubilee with 5.7L Propeller dsaville Prop Talk 4 07-30-2010 03:18 AM
    help with propeller size atisouth Prop Talk 3 07-13-2010 08:11 PM
    Advice for proper propeller for 2000 218 Shabah 5.0 merc I/O 250 H.P. rhtzi099 Original Mariah Talk 0 04-28-2009 12:18 AM
    Propeller choise Player311 Prop Talk 6 10-16-2007 11:42 PM
    Propeller for SC 21 Colin T Boating 101 3 09-08-2007 06:07 AM
    There are 283 users
