1996 shabah 252 slow out of hole
Prop Talk
Old 05-28-2012, 02:09 PM   #1
mark g truitt is currently offline
My Model: 252 Shabah
My Engine: 8.2 L, Bravo III
Send mark g truitt:
Default 1996 shabah 252 slow out of hole
Mine has the 501cc engine and it will fly once it planes out; however it is a dog out of the hole. I have the bravoIII so shouldn't it come out of the hole better?
  • Old 05-29-2012, 10:28 PM   #2
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: 1996 shabah 252 slow out of hole
    I had the same problem. Granted I have a 5.7 with the Alpha 1, but the same concept applies.... If your prop(s) are too steep, then you will gain top end and lose holeshot. Think of it as trying to take off in your car in 3rd gear. If you want to correct the problem, get a good WOT (wide open throttle) RPM reading and speed.... Then with a little research and math, you can figure out what props are right for you.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Jubilee 214 Too slow nooner Original Mariah Talk 2 02-02-2011 10:24 PM
    Big gapping hole wcso909 General Maintenance 1 10-06-2010 12:34 PM
    Hole Shot Getting Worse brettk Mercury MerCruiser 0 07-07-2010 12:04 AM
    slow shift into gear bubskunk Original Mariah Talk 0 06-15-2008 11:54 AM
    Hole shot Straad Prop Talk 9 08-13-2007 10:38 PM
    There are 319 users
