Dual prop?
Prop Talk
Old 05-15-2012, 02:27 AM   #1
janderson725 is currently offline
My Model: 222 Shabah
My Engine: 350 hp with Bravo III
Send janderson725:
Default Dual prop?
I've got a 2000 222. Currently it has a 24 pitch dual prop. I'm getting 55 mph or so with 4 people in the boat. It has great acceleration, but I'd like to get more top end speed. The boat has a new ram jet 350. Ive been reading the posts from people who are hitting 65 or 70. Are they using singe or doubles? Any suggestions?
  • Old 05-15-2012, 02:37 AM   #2
    Default Re: Dual prop?
    Hitting 65-70 in a 222 with a 350?? Really???? Sorry if i'm sounding just a little skeptical. You might want to ask those people who are making those claims about their set-up. Changing props to get more speed means a sacrifice elsewhere and that usually means it will be slow out of the hole. The duoprop does cause slightly more drag but with much improved handling.
    janderson725 (05-16-2012)
    Old 05-15-2012, 02:41 AM   #3
    Send janderson725:
    It does handle well, maybe I should just stick with what I've got. My old ski boat had a single prob with a v-6 and would get up to 55. I'm really curious what the differences are in a dual vs single set up. This is my first boat with a dual.
    Old 05-15-2012, 02:46 PM   #4
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    The dual props are for holeshot, like you've noticed, and dock manners, like Mikey mentioned. Just like a single prop, if you're hitting your max RPMs at WOT then you pretty much have it setup right.
    Thank you Dredd for this useful post!
    Old 05-16-2012, 09:21 PM   #5
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    From what I have read, the dual prop setups are a little slower on top end due to the added drag.... but much better at pulling and planing.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Dual Battery System twospeed46 General Maintenance 6 06-18-2018 02:46 PM
    Dual or Triple? csterner Trailering and Tow Vehicles 16 04-19-2011 06:20 PM
    Dual Battery Set Up firebirdzig Original Mariah Talk 1 03-30-2010 12:55 PM
    Dual battery Jbetschart Original Mariah Talk 5 11-04-2009 04:37 PM
    dual use battery? pimpadelic Original Mariah Talk 1 08-11-2009 02:15 PM
    Total Members: 18,995
    Total Threads: 13,326
    There are 265 users
