high five prop
Prop Talk
Old 05-01-2012, 01:57 AM   #1
Andy-Z202 Shabah is currently offline
My Model: Z202 Shabah Limited Ed
My Engine: Mercruiser 350 MAG MPI
Send Andy-Z202 Shabah:
Default high five prop
I have a 1998 Z202 shabah and I was curious if a high five Mercury Marine Part# 48-815758 would fit my drive?
  • Old 05-01-2012, 02:46 AM   #2
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: high five prop
    Mercury made 2 different hub sizes. (3 and 4 inch I believe). I THINK that all of the I/O's were the 4" hub. The highfive uses a hub kit (basically interchangable splines) that you buy separately. So as long as it is the correct hub diameter, just buy a hub kit for a merc and you should be good to go. I put a highfive on my boat last year and it is by far the best modification I have done. IF you are looking at buying a new one, check out nettles props. They are the cheapest, and great to deal with!
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 05-01-2012, 03:15 AM   #3
    I appreciate the feed back DCB MINDED and I'm glad to hear that you are happy with your High Five!
    Happy Boating my friend!
    WOT RPM's too high KeepitReal Mercury MerCruiser 4 07-29-2011 02:19 AM
    High-pitched alarm sound & high temp at high RPM petemcrunnel Original Mariah Talk 7 06-15-2011 05:57 PM
    High Five grommett Prop Talk 15 04-27-2011 07:08 PM
    High 5 Prop? SEMIJim Prop Talk 8 07-16-2009 02:03 PM
    High RPMs gcvaldez Prop Talk 4 07-25-2008 10:43 PM
    There are 250 users
