dual use battery?
Old 08-11-2009, 01:07 PM   #1
pimpadelic's Avatar
pimpadelic is currently offline
My Model: 1996 180 shabah 3.0L Alpha I Gen II
Gallery Images: 7
Send pimpadelic:
Default dual use battery?
has anyone tried to use one of the starting/deepcycle batteries in their boat? i was going to add a deepcycle battery and put in a switch. but has anyone tried the dual purpose batt?
  • Old 08-11-2009, 02:15 PM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: dual use battery?
    IMO: For casual power-boating use, in a smaller power-boat, a dual-use battery is fine. That's what I just installed on our Barchetta.
    But understand: It won't do one very important thing that a two-battery system with a switch will do: Prevent you from running-down the battery and leaving yourself w/no starting reserve. Nor will you have a back-up should your one-and-only battery suddenly go bad.
    If you're just on small, in-land lakes where there are people around all the time, probably NBD. But out on the big lakes, or in open seas, not recommended.
    I'm probably going to back-stop our single battery with a good jump box.
    Jim
    Dual Battery System twospeed46 General Maintenance 6 06-18-2018 02:46 PM
    Dual battery tougher than I thought blockp Mercury MerCruiser 2 06-24-2009 04:48 PM
    Factory Dual Battery Setup? If not... HELP! stereoman405 Original Mariah Talk 4 05-01-2009 05:27 AM
    Mariah returns to dual stripes MariahMan Sea Fox - Mariah Talk 3 12-04-2007 08:45 PM
    There are 374 users
