Eva foam flooring
Projects
Old 05-26-2023, 06:26 PM   #1
Mtweber86 is currently offline
My Year: 2002
My Model: Z275
My Engine: 6.2 bravo III
Send Mtweber86:
Default Eva foam flooring
Hello I was wanting to put some Eva foam flooring down to replace our carpet. Has anyone done this I planned to use the carpet as a template to make it easier. However I was wondering if you anyone has ordered and pre cut ones for their boat. All the site I’ve looked at don’t have Mariah listed for any template. Thanks for any help
  • Old 05-26-2023, 09:29 PM   #2
    SCbstewart302shabah is currently offline
    My Model: Z302 Shabah
    My Engine: 502 Magnum
    Gallery Images: 3
    Send SCbstewart302shabah:
    Default Re: Eva foam flooring
    I used a similar company, it’s not too difficult to do a template. I just went to Lowes/Home depot, bought a roll of heavy construction paper. It’s used on floors to protect the floors while work is being done in a home. If you take that and a trim knife/box cutter. Just lay this into the area and cut the edges, tape it together really well in the seams. Just act like you are laying this paper in your boat as carper. You can draw on it, makes notes for the Carpet manufacturer, basically you can white all over it. Most importantly, cut it to fit exactly the way you want the new floor to be. Then you can just roll it up and mail it to them (in a tube from UPS store) . This method worked really will for me.
    Old 05-26-2023, 10:04 PM   #3
    My Year: 2002
    My Model: Z275
    Send Mtweber86:
    Ok thanks I may try that. I have some samples on the way I was goin to play with. I don’t think it will be that hard to tackle
    Old 05-30-2023, 01:22 PM   #4
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    I've checked into it also and what is posted above is the typical process. Nobody has Mariah patterns so you will need to create a template for them. If you do, make sure you take your time and make the template perfect and your finished product will look fabulous.
    Dx212 non slip flooring vbadillo Sea Fox - Mariah Talk 1 02-25-2022 04:42 PM
    Seadek flooring over plywood FamilyFun Projects 3 07-14-2018 11:13 AM
    Fiberglass Flooring mark43 Original Mariah Talk 1 09-27-2012 12:52 PM
    Deck flooring on a 1994 Davanti? sanukc Original Mariah Talk 8 11-02-2010 08:37 PM
    Wanted: Windshield foam? wwjdato Mariah Parts For Sale & Wanted 1 03-17-2010 10:48 PM
    There are 342 users
