Deck flooring on a 1994 Davanti?
Old 10-10-2010, 05:18 PM   #1
sanukc's Avatar
sanukc is currently offline
My Model: 205 Davanti
Send sanukc:
Default Deck flooring on a 1994 Davanti?
Does anyone know if a 94 Davanti had marine plywood deck flooring under the carpet or fiberglass? Is there wood in the transom either? What parts are susceptible for wood rot?
  • Old 10-12-2010, 06:21 PM   #2
    sanukc's Avatar
    Send sanukc:
    Default Re: Deck flooring on a 1994 Davanti?
    Anybody? Anything?
    Old 10-13-2010, 05:42 AM   #3
    simpleaz's Avatar
    simpleaz is currently offline
    Send simpleaz:
    not certain but for the year I am sure it is wood. search some and you will find some photos of a few
    1996 Mariah Shabah 200 5.7L
    Old 10-13-2010, 03:55 PM   #4
    sanukc's Avatar
    Send sanukc:
    How suceptible to wood rot is the decking of a 94 Mariah? The boat I am looking at is extremely well cared for. The owner has the boat in storage 8 months of the year and has taken good care of it. I am just wondering because of the wood floor, if I should run away from the boat? The boat and engine has like 300 hours on it and is in great condition as far as I can see.
    Old 10-13-2010, 04:39 PM   #5
    skiater is currently offline
    My Model: Z182 Shabah
    My Engine: 4.3 merc
    Gallery Images: 3
    Send skiater:
    Sounds like the boat you are looking at is in very good condition, should not be any issues with wood rot.
    Take a look in the promotional brochures section of the forum, the 1994 catalogue is in there.
    There is a cross-sectional view of the laminate construction, also details the type of superior, (rot resistant) wood that was used for construction.
    I believe there are some posts on hull blistering reported on boats from this era which you should read, try using the search function.
    Old 10-16-2010, 02:48 AM   #6
    Captain Steve's Avatar
    Captain Steve is currently offline
    Send Captain Steve:
    The carpeted deck in my 1997 looks to be built from treated plywood. At the drain hole through the transom I also see what looks like treated plywood. I don't believe it is susceptible to rot. A neighbor of mine recently restored a small tri-hull. Its transom was not only rotten, it had carpenter ants nesting in it. He had to re-wood the transom and lay and glass-in new stringers as well.
    Captain Steve
    Valparaiso, IN
    Old 10-30-2010, 09:38 PM   #7
    dlowings's Avatar
    dlowings is currently offline
    My Model: Z225
    Gallery Images: 8
    Send dlowings:
    Correct me if I'm wrong, but I think all these are wood floors that are covered in a coat of fiberglass.. Then the marine carpet goes over the top of that... The fiberglass coated wood ties directly to the stringers no?
    Old 11-02-2010, 08:30 PM   #8
    845paulg is currently offline
    My Model: Shabah Z 272
    My Engine: 7.4 L MPI Bravo III
    Gallery Images: 12
    Send 845paulg:
    Yes its wood. I just redid my floor in a 1996 Z 272. The wood is 7 ply 3/4 inch Marine grade pressure treated plywood. I replaced with 12 ply marine grade plywood at 110 dollars a sheet!!! My boat was negleted though. If your boat was cared for and kept covered (dry). Your floor should be fine. Standard from mariah factory, the floor should be fiberglassed with the exception of the panel that covers the gas tank. I re-glassed over everything, including doulbe wrapping angle chages and the plywood seams which was not necessary at all. Also, with the exception of the centergas tank and ski locker, all compartments are spray foamed wich was a nice surprise.
    Hope this helps. Paul
    Old 11-02-2010, 08:37 PM   #9
    dlowings's Avatar
    My Model: Z225
    Gallery Images: 8
    Send dlowings:
    Any pics by any chance?
    1994 205 Davanti info? sanukc Original Mariah Talk 8 09-24-2011 08:26 PM
    1994 Z241 Davanti - $14,000 iamkeith Mariah Boats For Sale & Wanted 0 08-10-2010 11:22 PM
    94 Davanti Swim Deck brettk Original Mariah Talk 0 05-14-2009 04:52 PM
    1994 Davanti Z235 300sflyer Original Mariah Talk 0 12-11-2008 07:53 PM
    1994 DAVANTI 225 on EBAY jonesjchad Mariah Boats For Sale & Wanted 5 05-14-2008 08:54 PM
    There are 361 users
