Trailer bunk replacement
Projects
Old 04-13-2017, 02:51 PM   #11
My Model: Z202
Send Firestone:
Default Re: Trailer bunk replacement
Look great
John
  • Old 04-13-2017, 04:23 PM   #12
    zrbart2000 is currently offline
    My Engine: 4.3 alph LH
    Send zrbart2000:
    Originally Posted by MTH View Post
    Got the bunks covered in carpet. I beveled and sanded the top edges of the wood before just to make sure there were no sharp edges to push into the hull. I like the black a lot better than grey already!
    I double layered the back halves of the main bunks since that should be where most of the sliding happens. The bunk carpet actually feels pretty tough, better than I thought for some stuff I bought at Academy sports.
    Looking Good !!
    Old 04-14-2017, 08:49 PM   #13
    ROY850 is currently offline
    My Model: 202 Shabah
    My Engine: 4.3L alpha one
    Send ROY850:
    Wow! That's looks awesome. It's does look so much better black. Great job
    Old 04-18-2017, 06:00 PM   #14
    MTH Thread Starter
    MTH's Avatar
    MTH is currently offline
    My Model: Shabah 202
    My Engine: 5.7L A1
    Send MTH:
    I forgot to take a 'before' pic without the boat on it, but here is the result when completed! Did it near the ramp at the lake with some wrenches and power tools, took about 45 minutes total... not too bad!
    Also took the boat on the first spring drive, it did pretty well! It didn't want to start, even with a brand spanking new battery it acted like it didn't have the juice to crank it (rapping tapping noise when turning the key I believe is starter solenoid) but I turned the crank by hand just a 1/4 turn and it finally fired up right after. Drove it for around 30-45 minutes straight then came back in. After I got home I put my smart charger on the battery and it only showed to be at 50-75% charged, this is a 1000 MCA Exide battery, so I need to dig into that a little more. Once I got it started it ran great though
    99 Shabah 202 5.7 A1
    Old 04-18-2017, 08:49 PM   #15
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Excellent work. Everything on your rig looks like new.
    Thank you GaryDoug for this useful post!
    zrbart2000 (04-18-2017)
    Old 04-18-2017, 09:12 PM   #16
    Send zrbart2000:
    Looking real good. Hope mine turns out that well.
    Old 04-18-2017, 10:21 PM   #17
    MTH Thread Starter
    MTH's Avatar
    My Engine: 5.7L A1
    Send MTH:
    Thanks fellas. It's a really nice trailer, I felt like it deserved some love. It really pulls great.
    Now if only I could learn to pull the boat on straight every time!!!
    Firestone and ROY850 like this.
    Old 04-22-2017, 09:01 AM   #18
    My Model: Z258
    My Engine: 7.4 & Bravo 3
    Send 99 Mariah 258:
    Just went on the same mission. I bought some trailer bunk carpet on eBay and it was pretty good. I saw the slides people are talking about but they're some type of plastic/composite you screw on top of the carpet. I chose not to use them because the hull would sit on the slides instead of the whole bunk.
    As for your boat not starting. Definitely make sure your battery is good but check your ground connections. Especially the one that screws to the back of the block.
    File Type: jpg 704F8EE0-DF2C-419E-A0F1-6000D9150660.jpg (232.5 KB, 22 views)
    Firestone and MTH like this.
    Old 04-24-2017, 12:44 PM   #19
    MTH Thread Starter
    MTH's Avatar
    My Engine: 5.7L A1
    Send MTH:
    Nice! You went even further with yours getting the axles off. Looks great so far!
    I appreciate the info! I'll get in there and really look at the connections, maybe it will be something simple as some corrosion...
    Roller trailer vs. bunk trailer mihatran Original Mariah Talk 6 11-08-2012 11:03 AM
    trailer bunk spacing!!!!! help!!!! billrespass Introductions 2 08-01-2012 09:58 AM
    Trailer bunk rotted baker721 Trailering and Tow Vehicles 2 03-04-2012 02:20 AM
    Chariot Trailer Lower Bunk Size Vacation Dave General Maintenance 5 10-15-2010 10:33 PM
    Trailer bunk slides or glides rusty Trailering and Tow Vehicles 2 07-30-2009 08:53 PM
    There are 314 users
