Sonar/GPS Install
Projects
Old 08-24-2016, 04:44 AM   #1
Ramsey is currently offline
My Model: Shabah 202
My Engine: 5.1L Mercruser
Send Ramsey:
Question Sonar/GPS Install
I'm installing a new HumminBird helix 5 sonar/gps in my 21 ft, 2000 Mariah Shabah 202. How do I wire it to an accessory switch? Is orange wire positive and black negative? Also do I need to install the inline 3 amp fuze or wire it to the accessory switch then change that fuze (in fuze box) to a 3 amp? If I had a diagram of the fuze box, then could I wire the power for the unit to the accessory connection at the fuze box?
Sorry for the remedial questions, any advice would help.
Ramsey
  • Old 04-04-2017, 06:04 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Sonar/GPS Install
    How did the project turn out?
    John
    Old 04-04-2017, 09:30 PM   #3
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Just in case anyone else has this question: I just traced out the wiring for my SimRad Sonar/GPS unit which was installed before i bought the boat recently. It was wired directly to one of the the behind-dash fuse panel spare positions so that it would not require any switch to be on for power. I think that would be most convenient since it draws a tiny amount of power when turned of at the front panel. The spare position used a spade quick-on terminal.
    fish finder , gps
    Tower install Bosgarage57 Original Mariah Talk 29 07-02-2015 06:54 AM
    thru hul lexh. install greg1116 Original Mariah Talk 11 06-07-2013 07:58 PM
    Sonar Repairs ColoradoDiablo Chit Chat/Off-Topic 4 01-25-2012 02:54 AM
    XM Radio install spinks99 Projects 2 05-06-2010 02:35 AM
    Almost done with A/V Install! Z275 Original Mariah Talk 4 04-14-2008 07:46 PM
    There are 312 users
