Roller trailer vs. bunk trailer
Old 11-06-2012, 03:19 PM   #1
mihatran's Avatar
mihatran is currently offline
My Engine: 4.3 Alfa I
Gallery Images: 9
Send mihatran:
Default Roller trailer vs. bunk trailer
Did anyone use/have rollers instead of bunks on the trailer? I don't like the trailer that came with my boat when I got it and I would like to replace it with a tandem one. The boat should be around #2700-#2800 dry and I don't tust this trailer with single axle. I found a Shorelend'r but it has rollers. I red a lots of comments regarding demaging the hull but most of them were for Boston Whalers boat. Do you think will be ok for a Mariah boat? I've seen somewhere on the internet saying you have to have enough rollers (to not exceed #150/roller).
1994 Shabah Z212 with Merc 4.3LX Alpha I drive
  • Old 11-06-2012, 04:46 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: Roller trailer vs. bunk trailer
    Roller trailers are often meant for shallow/less steep ramps. I've also heard of rollers damaging hulls. Knowing the stringer system in a Mariah, I'd say you're probably ok especially with as many rollers as possible. But I'd still highly prefer bunks. Whether it's a single axle or tandem, that totally depends on the axle weight rating. Just remember, tandems are much more difficult to turn and roll around into a tight garage or parking space.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 11-06-2012, 05:11 PM   #3
    mihatran's Avatar
    Gallery Images: 9
    Send mihatran:
    The problem with my trailer is... well, I don't think that one axle is greater than #3500 (I don't know how to check that).
    Old 11-06-2012, 05:29 PM   #4
    Look over the axle tube closely. Mine is stamped on the outer end of the axle next to the hub assembly.
    Only other way I know is to measure the spindle on the axle. The part that the hub rotates on.
    Larry
    Old 11-06-2012, 07:45 PM   #5
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    The axle should be stamped. Is the trailer a factory trailer or another put with the boat later in it's life? I hate rollers... That's just me.
    Old 11-08-2012, 12:52 AM   #6
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Not a fan of rollers either. I think your bunk style trailers give much better support especially if you ever have rough roads you travel on. If you do go rollers, make sure you get as many as possible and NEVER leave the plug in the boat!(which is a good rule of thumb any time)
    Zack
    1994 Z212 Shabah
    Old 11-08-2012, 11:03 AM   #7
    mihatran's Avatar
    Gallery Images: 9
    Send mihatran:
    My trailer is manufactured. I can't check the load on axle because the boat is in storage. The trailer that I found to buy is a tandem for boats up to 23' and it has 48 rollers. When I asked the question was for the boat not for me how to handle it at the ramp. There are some boats which you never should load on rollers and I just wanted to be sure if Mariah is one of them. Thanks for the answers.
    trailer bunk spacing!!!!! help!!!! billrespass Introductions 2 08-01-2012 09:58 AM
    Trailer bunk rotted baker721 Trailering and Tow Vehicles 2 03-04-2012 02:20 AM
    Chariot Trailer Lower Bunk Size Vacation Dave General Maintenance 5 10-15-2010 10:33 PM
    Trailer bunk slides or glides rusty Trailering and Tow Vehicles 2 07-30-2009 08:53 PM
    Looking for a trailer 22empire Other For Sale 6 04-18-2009 02:35 PM
    There are 257 users
