What kind of fuel do you use?
Old 07-30-2014, 10:44 PM   #1
Smokymance's Avatar
Smokymance is currently offline
My Model: 182
My Engine: 4.3L MerCruser Alpha 1
Send Smokymance:
Default What kind of fuel do you use?
Iv searched a bit and didn't really find a clear answer.
What kind of fuel do you guys run on your Mariah?
My previous owner told me he has been using ethanol free gas ever since her has had the boat and he recommended i do to. I have no issue paying a little more for recreational fuel with no ethanol, especially since i barely go thru any gas.
182 Barchetta 4.3L 4BBL V6, Alpha One, 21P SS Prop, 60# SX Smart Tabs.
  • Old 07-31-2014, 12:37 AM   #2
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Default Re: What kind of fuel do you use?
    Been running 87 regular unleaded for 20 years now with no problems.
    Old 07-31-2014, 01:39 AM   #3
    Our fuel up here is still ethanol free but i do run mid grade (89) nearly all the time.
    Old 07-31-2014, 02:12 AM   #4
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    what do they charge you for ethanol free 89?
    Old 07-31-2014, 02:34 AM   #5
    Runs about $1.42 litre which is about $5.38 per US gallon
    Old 07-31-2014, 02:35 AM   #6
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    sounds about right...im at $5.25 for ethanol free gas on the water.
    Old 07-31-2014, 01:55 PM   #7
    Valvtect Marine Fuel (non-ethanol)
    Last time I filled up it was about $4.49/gal on the water, and about the same on the land (there's only a few stations around that sell non-ethanol gas on the land)
    Old 07-31-2014, 02:07 PM   #8
    LOTO Z240 Talari's Avatar
    LOTO Z240 Talari is currently offline
    My Engine: 454 Mag BR1 GenV 365hp
    Gallery Images: 29
    Send LOTO Z240 Talari:
    I run 89 octane ethanol free when I buy fuel on the water from several of the lake marinas. The current cost for 89 octane on the water is $4.45 / gallon. BUT..... I put in 15 gallons of 91 octane ethanol free before I lower the boat into the water for the weekend.The current cost on the 91 is $3.85. Makes a huge difference in performance just mixing 15 gallons of 91 with 30 gallons of 89. As far as 87 octane, I know a lot of guys like it, thats great! In my case, I experience a big fall off in performance. The way I figure it, if I use 40-50 gallons a weekend I spend an extra $16 to enjoy better hole shots and much better top end.
    Maybe I'm in the minority on the question of getting the best fuel you can for the engine? Just my opinion, but I always pass on 87 when 89 and 91 are available.
    Old 07-31-2014, 03:47 PM   #9
    If I can find it- Ethanol free. If not... I must be in Colorado! Only times I get the BS free fuel I've been out of state. Lake McConaghy had the BS free 87 for 3.95 which was not bad considering my 87 E10 fuel here in Colorado is 3.60...
    The big thing I notice is the boats ability to fire up instantly once the ignition is activated.
    There is a place that sells 93 non ethanol but I don't new the octane nor do I need the nearly $5 per gal price tag. (Maybe before I winterize?)
    Old 08-01-2014, 01:18 AM   #10
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    Our local FS carries premium ethanol free fuel so that's what I use. It's rare to find that around here.
    Patrick
    ethanol , free , fuel , gas , recreational
    What kind of strainer to use? csterner Mercury MerCruiser 0 05-19-2011 08:47 PM
    fuel tank capicity and fuel milage talari z Boating 101 2 08-01-2010 12:01 PM
    There are 375 users
