Depth finder advice? in dash--
Old 05-28-2014, 04:32 PM   #1
mustang_saily is currently offline
My Model: Barchetta
My Engine: in/out merc
Send mustang_saily:
Default Depth finder advice? in dash--
Hi,
looking to swap out a dead depth finder in my 1995 Barchetta, any advice/warnings? looking at the
HawkEye® In Dash Depth Finder/Sounder - Transom/In-Hull Transducer
  • Old 07-24-2014, 02:28 AM   #2
    Smokymance's Avatar
    Smokymance is currently offline
    My Model: 182
    My Engine: 4.3L MerCruser Alpha 1
    Send Smokymance:
    Default Re: Depth finder advice? in dash--
    any pictures of ur current unit? i have the same exact boat and looking for ideas where to mount the gauge
    182 Barchetta 4.3L 4BBL V6, Alpha One, 21P SS Prop, 60# SX Smart Tabs.
    Old 07-24-2014, 04:37 AM   #3
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Mounted mine between the speedometer and tach.
    Old 07-24-2014, 05:32 AM   #4
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    What brand do you have ?
    Old 07-24-2014, 07:05 AM   #5
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    '95 Barchetta 192 here and mounted mine between tach and speedo also. Its a Lowrance LST-3800. I can take a picture of it if you'd like to see. You wouldn't know by looking it wasn't put there by the factory.
    Old 07-24-2014, 12:35 PM   #6
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    A picture would be nice if you get a chance. is the sensor out the back or in the bilge area?
    Old 07-24-2014, 02:19 PM   #7
    husker_fan's Avatar
    Send husker_fan:
    Mine is out the back, but its not a factory unit. I added it. I think most factory ones are shoot through hull.
    Old 07-24-2014, 11:40 PM   #8
    husker_fan's Avatar
    Send husker_fan:
    Here's what mine looks like.
    Old 07-25-2014, 03:55 AM   #9
    My Model: Barchetta
    Send mustang_saily:
    wow...that turned out nice...I have one installed but doesn't work...any ideas why it wouldn't work? so that's why I'm looking to install a new one....
    Old 07-25-2014, 02:09 PM   #10
    This is another of those questions that gets asked quite often.If you are getting erratic readings usually the problem is with the transducer. If its attached to the hull under the motor check to see if its firmly attached. If it's loose then you can simply re-epoxy it back into place. If you are getting no read-outs at all, i would check the power and the ground wire connections. Do a site search for transducer or depth finder and you will find a number of threads discussing this topic.
    barchetta , depth finder
    Anybody having trouble with their OE depth finder? Purple_Shabah Original Mariah Talk 28 06-29-2016 01:51 PM
    Depth Finder diablo18 Original Mariah Talk 14 05-28-2013 02:15 PM
    Depth finder gauge Jaztwnz General Maintenance 11 05-15-2013 06:39 PM
    Depth Finder jchestnutt Introductions 1 05-06-2012 12:16 AM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    There are 387 users
