First outing on water since restoration- this weekend
Old 04-21-2014, 04:24 AM   #11
Default Re: First outing on water since restoration- this weekend
Just for giggles Paul , wire open the choke and try her.
Definitely sounds like a fueling issue.
  • Old 04-21-2014, 04:27 AM   #12
    Txtruckerpaul's Avatar
    My Model: Z240 talari
    My Engine: 7.4 bravo III
    Send Txtruckerpaul:
    Tried that and it would barely get started. Seems to idle better with the choke 3/4 closed. That made me think it was an idle screw issue. Messed with them and no dice
    Old 04-21-2014, 05:50 AM   #13
    WillinWA is currently offline
    My Model: 220 Talari
    My Engine: 5.7L alpha
    Send WillinWA:
    Nice job on the restoration and congrats on getting out on the water! Can't wait to get mine out of storage and get it going!
    Old 05-15-2014, 11:19 PM   #14
    Send Txtruckerpaul:
    Haven't been on here in a while, but think I solved part of my carb problem. Took the carter AFB apart and noticed the two springs for the metering rods were different from each other. One took a lot more effort to compress down than the other. When idling, manifold vacuum keeps these rods pulled down into the jets, restricting the fuel flow. As you throttle up and vacuum decreases, the springs lift the rods out if the jets, allowing more fuel. I'm suspecting the stiffer spring is holding the rod out of the jets at idle/ slow speeds and allowing way too much fuel into the venturis and running rich. Still haven't found out why it's cutting out at wot or why it's hesitant on acceleration after running for awhile. Checked fuel and tank and new filter. All are very clean. Maybe it was trying to flood out since it was getting too much fuel anyways. We'll see.
    Restoration mikey Original Mariah Talk 7 04-19-2012 01:28 AM
    1st Outing of 2011 KSMariah66061 Introductions 1 06-11-2011 05:38 PM
    1st outing a disaster wweathers Prop Talk 9 09-04-2010 12:31 PM
    First outing of the season a bust Nathan5678 Original Mariah Talk 6 06-14-2010 06:25 AM
    First weekend on the water! 180diablo Trips, Travels, and Meet Ups 5 06-26-2008 07:43 PM
    There are 362 users
