94 Barchetta switch problem
Old 05-14-2014, 11:54 PM   #1
biker is currently offline
Status: In Limbo
My Model: 18.5barchetta
My Engine: 4.3 L
Send biker:
Default 94 Barchetta switch problem
I just got a 94 barchetta the switches arnt working
  • Old 05-15-2014, 01:45 AM   #2
    Default Re: 94 Barchetta switch problem
    That is a problem isn't it. Are you asking for some help or just making a statement?
    btw....welcome aboard.
    The Following 2 Users Say Thank You to mikeyt For This Useful Post:
    biker (05-15-2014), Motoxxx43 (05-15-2014)
    Old 05-15-2014, 04:31 AM   #3
    Status: In Limbo
    My Engine: 4.3 L
    Send biker:
    need help
    Old 05-15-2014, 12:24 PM   #4
    You're going to have to supply a heck of a lot more info on the problem than just the switches aren't working!
    We're good around here..........but we aren't that good.
    Old 05-15-2014, 12:45 PM   #5
    Status: In Limbo
    My Engine: 4.3 L
    Send biker:
    well one of the switches lights up others dont work nav light blower pump in lights checked grounds on bettery
    Old 05-15-2014, 01:00 PM   #6
    They are run in a series from one switch to the next on the ground side usually starting from the switch closest to the steering column. Is that switch working biker?
    Switch contacts , and fuses are notorious for corrosion on the spade.
    As for not lighting up , could just be the small bulb for that switch is burned out.
    I'd use a test light , and start chasing from the fuse panel to the switches.
    I meant the ground side biker , sorry my bad.
    biker likes this.
    biker (05-15-2014)
    Old 05-15-2014, 01:36 PM   #7
    As Larry suggested, corrosion is the number one electrical problem in boats. Check/clean your connections and use the test light to see if power is getting to the switch. If power is there then yes its possible the switch(es) have finally failed & need replacement. If you need replacement parts check our Original Mariah Vendors list for a supplier.
    New to me 96 Barchetta 182 lwillson Introductions 3 05-23-2013 10:48 PM
    battery switch location problem nav-tek marine Original Mariah Talk 2 09-02-2011 12:42 AM
    Problem with Ignition Switch lmdengler Original Mariah Talk 3 05-31-2011 12:43 AM
    What does this switch do? Frankpypr Original Mariah Talk 4 06-16-2010 03:29 AM
    94 182 barchetta brett weber Introductions 6 02-20-2008 05:38 PM
    There are 276 users
