Boat doesnt like to start when hot....
Old 04-18-2014, 05:20 PM   #1
swoodworth is currently offline
My Model: Z202 shabah
My Engine: 5.7L
Send swoodworth:
Exclamation Boat doesnt like to start when hot....
Hey guys....not too sure where to go with this one....I have a 95 Mariah Z202 that doesnt like to start back up after sitting hot for awhile. She starts right up cold no problems but if we crusie around for awhile and then stop at the sandbar for 30 minutes or so and then decide to take off she has a tough time starting back up . Any help would be much appreciated!!!!
thanks!
Mariah1 likes this.
  • Old 04-18-2014, 08:30 PM   #2
    Default Re: Boat doesnt like to start when hot....
    This is a common problem. Replace the coil and the ignition module in the distributor.
    krissy7447 (11-08-2016)
    Old 04-18-2014, 08:41 PM   #3
    My Engine: 5.7L
    Send swoodworth:
    Thanks! Knew someone would have the answer! Any advice on where i should get the parts from?
    Old 04-18-2014, 09:10 PM   #4
    iboats.com works but there are likely hundreds of places where these are available.
    Old 04-20-2014, 02:27 AM   #5
    My Engine: 5.7L
    Send swoodworth:
    Thanks!
    Old 05-06-2014, 12:45 PM   #6
    My Engine: 5.7L
    Send swoodworth:
    Was able to get the new coil put in over the weekend, the actual module is another story! Turns out I was sent the wrong one...guess thats what I get for not opening the box before heading to the boat! Hopefully I can take care of it this weekend. Thanks for the help!
    Old 05-06-2014, 04:33 PM   #7
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Let us know if it cures the problem!
    Old 05-28-2014, 01:57 AM   #8
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Mine will start right up after sitting at the sandbar, but will stall after a minute and not want to start. Same problem?
    Old 05-28-2014, 12:43 PM   #9
    My Engine: 5.7L
    Send swoodworth:
    Think its a different problem....mine doesnt like to start after sitting but once it starts I am good to go! I changed the ignition coil and that didnt seem to help....need to get an new ignition module I think, but its real expensive so I am trying to find a good deal before I bite that bullet!
    Old 06-16-2014, 01:28 PM   #10
    My Engine: 5.7L
    Send swoodworth:
    Well I updated the module this weekend, started up fine no issues. However after we went to the sandbar and tried to start up after about an hour or so I had to keep the key cranked for a bit before the boat finally caught and started up. That being said it doesnt seem like the new module solved my problem....anyone have any other advice? Vapor lock? Starter going bad? I dont know where to start!
    Fordrich likes this.
    gimbal bearing doesnt wanna budge Txtruckerpaul Original Mariah Talk 9 03-22-2014 12:06 PM
    SX19 4.3 hard start then no start after cable adjustment Lucky14 Sea Fox - Mariah Talk 3 08-22-2013 11:54 AM
    Help - will not start LifeIsGood Mercury MerCruiser 4 08-20-2013 12:43 PM
    Suddenly my Boat won't start & trim doesn't work guyjusthere Mercury MerCruiser 16 01-06-2013 05:56 PM
    Boat won't start kgoo Original Mariah Talk 21 08-07-2009 06:25 PM
    There are 343 users
