Boat doesnt like to start when hot....
Old 06-16-2014, 04:35 PM   #11
gahooligan's Avatar
My Model: 202
My Engine: 5.7l
Send gahooligan:
Default Re: Boat doesnt like to start when hot....
Mine will do this while running Around and starting stopping(ie when starting the motor hen it hot) but if you give it about three quarters throttle to get it more air it starts right up. When it starts it has a nice rich smell lol.
  • Old 06-16-2014, 04:41 PM   #12
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    This is a common problem with the carbureted mercruiser engines. I 've been told that fuel evaporates from the heat while it's been sitting.
    I open my sun deck for a while and let the heat out while at the beach. Another suggestion was run the blower for a little while after shutdown.
    It only happens in hot weather to me.
    Old 06-16-2014, 04:50 PM   #13
    swoodworth is currently offline
    My Model: Z202 shabah
    My Engine: 5.7L
    Send swoodworth:
    I have tried opening up the throttle too while starting it but it still takes awhile to turn over...not sure what the problem is.
    Old 06-16-2014, 04:59 PM   #14
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    To turn over? Or it turns over fine but just won't start? if it's turning over slowly like its have a difficult time soininging the motor I would think it's possible that the starter is going bad or the connections and the heat is building resistance
    Old 06-16-2014, 05:01 PM   #15
    My Engine: 5.7L
    Send swoodworth:
    sorry...it turns over but doesnt start right up...I have to keep it turning over for a little bit before it will finally start up.
    Old 06-16-2014, 06:14 PM   #16
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    If you google "Mercruiser won't start when hot", you'll see you're not alone.
    Old 06-16-2014, 06:36 PM   #17
    My Engine: 5.7L
    Send swoodworth:
    Just googled that...thanks! Was trying to decide how difficult it would be to put an inline fuel cooler or insulate the fuel lines (which seems to be the easier fix?) but haven't had much time yet to do the research.
    Old 06-17-2014, 10:58 PM   #18
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    The old hot rodder approach is to remove the mechanical fuel pump, block it off with a plate and replace it with an electric pump. The reason you have to crank the motor so long is the mechanical fuel pump has to refill the empty (boiled off) fuel bowl. An electric pump begins pumping as soon as you turn the key.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-20-2014, 06:50 PM   #19
    My Engine: 5.7L
    Send swoodworth:
    thanks for the input...guess I will start researching that to see how difficult it will be! thanks!
    Old 11-07-2016, 11:28 AM   #20
    krissy7447 is currently offline
    My Model: Shabah
    Send krissy7447:
    Hello just wanted to see if you finally have a solution to your issue
    gimbal bearing doesnt wanna budge Txtruckerpaul Original Mariah Talk 9 03-22-2014 12:06 PM
    SX19 4.3 hard start then no start after cable adjustment Lucky14 Sea Fox - Mariah Talk 3 08-22-2013 11:54 AM
    Help - will not start LifeIsGood Mercury MerCruiser 4 08-20-2013 12:43 PM
    Suddenly my Boat won't start & trim doesn't work guyjusthere Mercury MerCruiser 16 01-06-2013 05:56 PM
    Boat won't start kgoo Original Mariah Talk 21 08-07-2009 06:25 PM
    There are 256 users
