rear deck over engine- whats the frame made of?
Old 02-22-2014, 01:49 PM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default rear deck over engine- whats the frame made of?
hi gang. looking at my talari's rear deck above the engine (the thing that is hinged and lifts up to access the engine compartment), looks like it bows up a little where the gas charged cylinders attach. is it a wood frame underneath the upolstery? the rest of it feels solid, but if its cracked or rotten under there, i need to get it fixed. wanting to get some insight from someone before i go to removing the vinyl
  • Old 02-22-2014, 03:22 PM   #2
    Default Re: rear deck over engine- whats the frame made of?
    Yes Paul , the hatch panel itself is made of wood. More than likely , it is just warped from age.
    You could use something like aluminum angle iron to straighten it out , but if at all possible in your budget , replace hatch panel with King Starboard and never have to worry about it again.
    Old 02-22-2014, 04:15 PM   #3
    Send Txtruckerpaul:
    Thanks Larry.
    What is king starboard? Haven't heard of it unless its a different name for marine grade wood
    Old 02-22-2014, 04:18 PM   #4
    Here is the info from their site.
    King Starboard
    It's a bit pricey , but it is awesome material to work with and it will last forever.
    Old 02-23-2014, 02:45 AM   #5
    Send Txtruckerpaul:
    I took a look at that stuff. Sounds like the ideal way to go! From what my wallet is barking at me, I probably better go back with wood for right now. This project is getting close to the budget warning level since I've taken the while interior out to have it reupholstered. I'll get some pics posted when I get it installed. Thanks for passing on the link. I'll save it
    Old 02-23-2014, 03:11 AM   #6
    Yes sir , the ol budget is always the deciding factor.
    Get us some pics when you get her done Paul.
    Canopy Frame robetello Original Mariah Talk 2 10-27-2010 03:49 AM
    New upholstery for sun deck/engine cover bdbyrnes Projects 28 01-23-2010 04:25 PM
    Gas Spring struts rear sun deck Billyclub Original Mariah Talk 0 05-06-2009 06:32 PM
    what is the flor made of? lucky77 Original Mariah Talk 4 08-02-2008 11:47 PM
    Sun Deck / Engine Cover Acadianbasic Original Mariah Talk 6 06-01-2008 01:14 PM
    There are 352 users
