Gas Spring struts rear sun deck
Old 05-06-2009, 06:32 PM   #1
Billyclub is currently offline
My Model: 1999 Shabah 182 Mercruiser 3.0L
Send Billyclub:
Default Gas Spring struts rear sun deck
I'm wondering if anyone knows the manufacture spec's for the gas spring struts that lifts the sun deck to access the engine compartment on a 1999 Mariah Shabah 182. Both of my springs are locked open and I need to replace both. The number on the springs are "SL34-90. I don't know if these are the original spring sizes. It seems to me that two springs of "90 lbs" pressure may be too excessive for what it is lifting. I suspect this because one of the mounts that attached the spring to the boat has pulled away from the boat. Any help is appreciated.
    Engine cover gas struts modification AndyFL Projects 5 09-22-2010 12:22 PM
    1996 Z272 rear corner seat removal. Argot Original Mariah Talk 4 08-11-2009 11:50 AM
    Spring Startup Help Corndog General Maintenance 7 02-18-2009 12:04 AM
    sx18 rear seats mashymariah General Maintenance 3 12-22-2008 03:22 AM
    Rear Seat Compartment drain boarder1010 Original Mariah Talk 9 06-09-2008 04:19 AM
    There are 315 users
