what type of maintenance should i consider over the off season.
Old 10-13-2013, 05:06 AM   #1
phillycincykid's Avatar
phillycincykid is currently offline
My Year: 1990
My Model: xlc 2150
My Engine: 5.7 l mercruiser
Send phillycincykid:
Default what type of maintenance should i consider over the off season.
year three with the original mariah has been great. i want to carry this great performance into the 2014 season. i have about 565 hrs on the clock.(5.7 v8) what im trying to figure out is what type of things should i be looking for or consider for maintenance issues this upcoming off season.
the beginning part of this year i did a tune up with new plugs and wires,thermostat, new water pump (outdrive) and new belts. other then the obvious oil change, fuel filter, carb rebuild and quite possibly a new outdrive b/c of a broken cavitation plate and the out drive is pitted beyond welding too. what else should i consider?
im all for preventive maintenance , i don't do cheap when it comes to things like this and will replace anything that is remotely questionable.
thank you
Mariah 1990 XLC 2150 5.7 V8 about halfway rebuilt.
  • Old 10-13-2013, 04:06 PM   #2
    Default Re: what type of maintenance should i consider over the off season.
    Sounds like you got it pretty well covered philly.
    Only thing I can think of right off the top of my head is maybe change the drive , exhaust , and shift boots out.
    Preventive maintenance is what keeps us on the lake and happy!
    Old 10-14-2013, 12:11 AM   #3
    My Year: 1990
    My Model: xlc 2150
    that was all done 2 years ago with the gimble bearing being replaced. whats great is i take on zero water. the only time the bilge pump goes off is when im stuck in the rain. does anything ever have to get done with the exhaust or the cooling passageways thru the engine? anything ever have to get taken apart or some sort of chemical run thru there just to get all the rust or old river nastiness out? i have no problem with keeping the engine cool , but like you said, a well maintained boat is a happy boat! and if i dont ever have to call a buddy to tow me back to port i will die a happy man!
    type of oil for 7.4 ??? gman Original Mariah Talk 0 06-06-2011 09:53 PM
    Type of tow vehicle? m&mmariah Trailering and Tow Vehicles 0 07-27-2010 04:28 AM
    Exact engine type help mjhinno Mercury MerCruiser 2 05-24-2010 05:29 PM
    What type of prop are you running on 182 Shabah? bbrophy58 Prop Talk 1 02-19-2010 09:59 PM
    type Numbers Shabah203 Original Mariah Talk 3 08-16-2009 02:41 PM
    There are 359 users
