thru hul lexh. install
Old 06-07-2013, 02:18 PM   #11
Default Re: thru hul lexh. install
If you're under noise restrictions, you're pretty much stuck with using an Mercruiser Captain's Call/Silent Choice or going with something aftermarket like:
IMCO Marine's Sound Advantage Exhaust System
This one's pretty cool, it allows you to fully adjust your exhaust completely rather than just routing it underwater, or out the thru-hulls. You can put 20% out the thru-hulls, and 80% out underwater, or any combo. It's not cheap though, much like ALL of the thru hull exhaust systems.
I guess the real question should be: If the lake you're on won't allow captain's call or thru-hull exhaust, then why would you want to put it on? It's eventually going to end up getting you ticketed or kicked out of a marina. Perhaps it's better to just save it for fuel instead.
  • Old 06-07-2013, 07:58 PM   #12
    Or for some beers!
    Tower Install jnd_v Original Mariah Talk 3 06-10-2011 08:49 PM
    Bimini Top install Jimh23 Original Mariah Talk 2 05-19-2010 07:08 PM
    XM Radio install spinks99 Projects 2 05-06-2010 02:35 AM
    280Z TV Install 2 OWNER MARIAH Original Mariah Talk 3 09-21-2009 03:16 PM
    Almost done with A/V Install! Z275 Original Mariah Talk 4 04-14-2008 07:46 PM
    There are 309 users
