7.4L MPI Stray Vaccuum Line
Old 05-30-2013, 04:20 PM   #1
jayws6 is currently offline
My Model: Z255 Shabah
Send jayws6:
Default 7.4L MPI Stray Vaccuum Line
Hi guys,
Was installing new bilge blowers last night and noticed a Vaccuum Line that originates from the front of the engine, to the right of the flame arrestor, tees into a small diaphram and the intake manifold, has the other end open. I'm not sure where the other end is supposed to go. Any ideas? Hope I was clear enough in describing it's location.
Thanks!
Jason
  • Old 05-30-2013, 05:46 PM   #2
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Default Re: 7.4L MPI Stray Vaccuum Line
    A picture is worth a thousand words
    Old 05-30-2013, 05:53 PM   #3
    Send jayws6:
    There is only one line off the front of the engine. Figured those with the same engine may be able shed some light. I can grab a pic this evening.
    Jason
    Old 05-31-2013, 01:07 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Jason,
    On my 1999 7.4 MPI, there is only one vacuum T. Obviously the T is fed from the intake manifold. The T branches off to the fuel pressure regulator on the "Cool Fuel Assembly" at the bottom of the engine on the port side. The other side of the T goes to a Fuel Pressure Damper which is mounted on the fuel rail on top of the engine. From your description it sounds like the errant vacuum line goes to the fuel pressure regulator.
    Hope this helps.
    rhinoz likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    mikeyt (06-07-2013)
    Old 06-07-2013, 02:44 AM   #5
    Send jayws6:
    Hey Steve,
    You got it!! I looked to the fuel cooler and sure enough, there was a vacuum line left open that I was able to plug the intake line into. Thanks very much for your help! Hopefully the previous owner didn't have it left open for a reason....
    Jason
    Old 06-07-2013, 02:49 AM   #6
    Excellent Steve. You are one of the very best mechanical / electrical guys we have around here!
    rhinoz likes this.
    Old 06-07-2013, 04:28 PM   #7
    My Model: Z280
    Mikey,
    Thanks for the kind words...just trying to help a fellow boater out!
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-07-2013, 04:32 PM   #8
    Send jayws6:
    And help out you did! Appreciate it. I never would have thought to look that far down beside the engine.
    Jason
    Drive line oil question Kitto Original Mariah Talk 7 07-05-2012 12:57 AM
    212Z fuel line pick up? gdsoper Original Mariah Talk 1 03-19-2012 04:13 AM
    Best way to fix a hair line crack? near windshield nglauer Original Mariah Talk 8 07-15-2010 09:48 PM
    Looking for my fuel line on a 94 shabah Jbetschart Original Mariah Talk 9 01-28-2010 07:43 PM
    oil line connection on lower unit shoc Mercury MerCruiser 4 05-15-2009 04:08 AM
    There are 301 users
