top speeds at wot. what are people getting for max speed?
Old 11-23-2012, 06:42 PM   #21
Default Re: top speeds at wot. what are people getting for max speed?
Originally Posted by jgreen View Post
Wow your wife lets you bring 25 gals with you.
Now that's a wife who is a good sport!
  • Old 11-24-2012, 08:30 PM   #22
    PlumLazy's Avatar
    PlumLazy is currently offline
    My Model: 210
    My Engine: 5.7, Bravo III
    Send PlumLazy:
    1994 Z211 Shabah, 5.7 Bravo III, 24P props. The wife and I, a cooler full of beer, msc junk, and probly 20 gal of fuel. 57mph in light chop on GPS with her yelling "slow down"... Didn't have time to check the tach, but around 4200. Hoping to get all the junk out of it and take it out one more time with a 1/4 tank and try to break 60 before I winterize her.
    Bob
    Canyon Lake, TX
    '94 Shabah Z211, 5.7 Bravo III
    Old 11-29-2012, 11:15 PM   #23
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    '97 Shabah 210 LE, 454 with bravo 1, not sure of prop (Boat is at the lake) 60+
    allz28 likes this.
    Old 12-04-2012, 02:01 AM   #24
    DougR is currently offline
    My Year: 2003
    My Model: SX 20
    My Engine: 5.7
    Send DougR:
    2003 sx 20, with a new vortex 350, 20 pitch four blade aluminum prop, four people and a half a tank of gas we get a solid 45mph on my gps...
    However, I'm thinking that might be pretty slow after reading some of the other posts...???
    Old 12-04-2012, 02:51 AM   #25
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    DougR... Probably not. Some people catch really, really BIG fish if you know what I mean. LOL!
    David240z likes this.
    Old 12-04-2012, 03:00 PM   #26
    Could be the prop being a 20p and a four blade. What are your RPMs at?
    I have the 4.3 V6 and I am in the low 40s with a 21p.
    Old 12-04-2012, 03:27 PM   #27
    You might be good for another 3-4 mph with a prop change but....that 20" 4 blade with the 350 pushing it should literally jump when you push the throttle down, have great mid-range response and provide excellent control pulling tubes/wakeboarders etc. That's a sacrifice i would be happy with because i try not to run at WOT.
    Old 12-05-2012, 09:45 PM   #28
    Jgos929 is currently offline
    My Model: 180SE Shabah
    My Engine: 4.3L Cobra
    Send Jgos929:
    I took my boat out Thanksgiving weekend for one last run to burn up some old fuel before I put her down for the winter. By the way it got up to 81* here yesterday so not sure how much of a winter we'll have.
    Anyways the lake was smooth as glass, perfect for the above scenario. It was just me, a full tank of gas (30 gallons) and a cooler with a 6pack in it. The boat is a 1997 Shabah 180se Limited Edition. I was able to run about 46mph (speedo) with the throttle pinned. Thats with a Volvo Penta 4.3L, Cobra SX outdrive, 14.25" x 19" 4 blade aluminum prop turning at about 5200rpm.
    I wasn't looking for top speed when I switched from the 3 blade to the 4 blade. We do a lot of tubing and skiing so I was looking for that out of the hole punch and mid-range power. Im sure I could get some more out of it with a 3 blade.
    Old 12-05-2012, 09:55 PM   #29
    You could get just a touch more with a 20" - 4 blade and lose very little of that punch. It will also get your WOT rpms down to about 4900-4950 which is close enough to the recommended range to be safe.
    Old 12-05-2012, 10:05 PM   #30
    Send Jgos929:
    Thanks for the tip Mikey. I might try out a 20" next spring and see what she does. At 5200 she was screaming so I didn't keep it there long. I prefer to keep it under 4500 and cruise in the mid 30s. My local lake isn't all that big and running 30-35 will get you where you need to go pretty quick.
    No Speed Lay Lake Mark Introductions 0 08-05-2010 12:47 AM
    top speed southcoastpower Original Mariah Talk 3 06-29-2010 09:30 AM
    With four people, I can't get it up. abillmann Original Mariah Talk 42 06-24-2009 01:47 AM
    hello people mark keough Introductions 4 07-14-2008 02:51 PM
    speed and rpm jktbea Original Mariah Talk 7 05-20-2008 03:51 AM
    There are 436 users
