top speed
Old 06-28-2010, 11:49 AM   #1
southcoastpower is currently offline
My Model: z2555
My Engine: 7.4 l Bravo III
Send southcoastpower:
Default top speed
my 1996 255z shabah with a 7.4 bravo 3 what should it be running rpm wise and what can i expect for speed. I think it is reving to high with 22p props. 4700 - 4800 ??? Love the boat i will never buy another boat other than Mariah it is awesome!!!!
  • Old 06-28-2010, 12:33 PM   #2
    Default Re: top speed
    Hi southcoastpower, Depending on whether you've got a Carbed or Injected motor,you're probably hitting close to 50 or so with the 22Ps.
    I think it is reving to high with 22p props. 4700 - 4800 ? What should it be running rpm wise?
    I believe the WOT RPM for the 7.4L should be between 4200 - 4600 (that's what's listed on our 96' 7.4L). Now depending on whether you're going for a better hole-shot or top end, the 22s will give you a slightly better takeoff where the 24s will give you a tad bit higher top speed. (we're only talking about 4oo RPM difference between the 22P and the 24P) so considering the cost for a set of B3 props, you may want to stay with the 22Ps and watch your WOT RPMs.
    Old 06-28-2010, 06:17 PM   #3
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Mr. Willy, good to see ya.
    Old 06-29-2010, 09:30 AM   #4
    Thanks Dredd
    TOP Speed Mariah SC25 with 5.0L TomasSE Sea Fox - Mariah Talk 17 07-05-2015 01:44 PM
    1996 Shabah 180 3.0 top speed? midwest mariah Original Mariah Talk 4 08-03-2009 04:43 AM
    Wasn't able to get normal top speed 94z190talari Original Mariah Talk 0 07-13-2009 03:44 AM
    Trimming Speed for Outdrive Douglas Alderman Original Mariah Talk 1 08-25-2008 05:18 AM
    speed and rpm jktbea Original Mariah Talk 7 05-20-2008 03:51 AM
    There are 336 users
