Battery operated hatch pt. II
Old 10-19-2009, 08:01 PM   #31
Jere McManus is currently offline
Send Jere McManus:
Default Re: Battery operated hatch pt. II
Thanks. I may check for a part number on those. The piano hinges, on mine, screw into the end and are starting to pull out on a few screws. It looks like your mounting is much stronger.
Jere
  • Old 08-02-2021, 08:59 PM   #32
    Kulak is currently offline
    My Model: Z220
    My Engine: 7.4 Bravo 3
    Send Kulak:
    Hi all, I have a 1994 Z220 Talari my hatch motors work very very slow. I disassembled them as much as possible and
    checked the motors, connected them to my 12V. battery. They seem to work fine. I took apart the screw drives and they were rusted up, so I cleaned them and greased them. Hooked them to the battery and worked like new. NOW the problem. Put them back in the boat and hooked them up and they were so slow I drank four beers. Then I disconnected them from the hatch thinking the hatch was too heavy and they were still like turtles. Could the switch be the problem? I pulled the switch and it wasn't corroded. I must not be getting the full 12 volts to the motors. One runs slower than the other. Any thoughts?
    Old 08-03-2021, 12:17 AM   #33
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Could be voltage drops in either the wiring or the switch.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-03-2021, 02:59 PM   #34
    Sparks&Stripes is currently offline
    My Model: Jubilee Z244
    My Engine: 350 Mag Alpha One
    Send Sparks&Stripes:
    I have heard factory actuators are very slow. I ordered a new one (my jubilee has one actuator and one lift assist cylinder) off amazon made by progressive automations model was PA-04-16-100 and they are marine grade and very quick. They have many sizes as well. $159...
    Dan
    Upstate NY
    98 Mariah Jubilee Z244 - 350 Mag MPI/Alpha1G2
    88 Seebold Eagle 21 Closed Bow - 175 Suzuki OB
    97 Celebrity 240 Cuddy - 7.4 Merc/Bravo1
    88 Larson Delta Conic 250 Aft Cabin - 5.7 Merc/Alpha1G1
    86 Thompson Open Bow - 3.0 Merc/AlphaG1
    Help! Need info on Engine Hatch Lift - Z302 milemarker60 Original Mariah Talk 6 07-13-2022 10:58 AM
    Battery Operated Hatch - Release Mechanism EBO Original Mariah Talk 10 02-03-2008 12:27 AM
    96 talari Z240 Engine Hatch Lift Help WetWilly Original Mariah Talk 8 10-02-2007 12:30 PM
    Battery Monitoring ShabahZ280 Boating 101 1 09-10-2007 11:31 PM
    Battery box full of water dudders General Maintenance 5 08-28-2007 12:35 PM
    There are 374 users
